No start problem/weather related
My cars done this twice in the past week now. Both times it has occured after sitting a long period of time in the rain. Both times I haven't had access to a fuel pressure gauge or had an extra set of hands around to check if I had spark. Last night I finally got fed up and just kept cranking on it, going WOT frequently so as not to flood it out. After a couple minutes I was able to get it to sputter a little and shortly after that it fired and started. After I let it run a few minutes I shut it off and it started right back up with no problem. Any ideas where to start? Has opti problems caused anything like this? Coil maybe? Could something be getting wet from the rain/damp air then drying out as I crank the motor over? Aaaaaaaargh
Re: No start problem/weather related
Originally Posted by slopokrodrigez
What happens if it sits for the same amount of time but there is no rain? Where is columbii?
Originally Posted by 94_Z28_guy
I had the same thing. One of my wires (coil to opit) was bad.
Humidity will collect on the plug wires and stop them from firing the plugs with old wires.
The moisture down in LA here is so bad that on occasions you can raise the hood and there is water on everything,like ya threw a 5 gallon bucket full under the hood after setting overnight. Your wires and opti have to be in good shape to take that.
This guy may have some helpful info: http://web.camaross.com/forums/showt...9&page=2&pp=15
Magenta_Hearts
Mar 29, 2017 08:54 PM
mspennyhughes
Mar 1, 2015 03:50 PM
Gtpguy
Jan 26, 2015 04:50 PM
