no start not firing
Old May 30, 2005 | 12:07 PM
96 trans am's Avatar
no start not firing
Hello everyone,
Well in the last few days I changed all my seals in my timing cover and replaced the timing cover gasket. I had the water pump, opti, timing cover, air pump, coil, hoses, and a few other things off, well I put everything back together, and now it turns over, but does not fire. Could it be that the wire from the opti to the coil is lose or what. Please someone let me know what is going on.
Old May 30, 2005 | 06:46 PM
Re: no start not firing
anyone???????
Old May 31, 2005 | 12:12 AM
bdc95ta's Avatar
check for pulses at the injector and spark.
-b
Old May 31, 2005 | 06:59 PM
well I noticed that all three of my grounds broke, that ground by the icm and coil, they are the three round grounds, they broke off on the end, would this let my car not fire, and what is the easiest way to fix this, someone please help me.
Old Jun 1, 2005 | 10:59 PM
bdc95ta's Avatar
yup, cut and splice the wire. Then crip those connecters (you can get them at lows) on it and tighten it down.
-b
Old Jun 8, 2005 | 08:48 PM
well got my grounds fixed, and still no fire, if I had my spark plug wires crossed, would it fire and run bad, or would it not fire at all, and what fuses should I check for?
Old Jun 9, 2005 | 11:16 PM
bdc95ta's Avatar
check the ign. fuse it's a 10amp.
-b
Old Jun 9, 2005 | 11:34 PM
turbo_Z's Avatar
You need to pull a plug wire to see if spark is making it to the spark plug first.
If you see spark but its not firing then you installed the opti incorrectly.
If there is no spark then check to make sure those grounds are good again b/c that will definitely create problems. Then pull the coil wire off the opti end and crank the motor to see if the coil is supplying spark to the opti. If its not then check all your fuses like was mentioned above, then check to make sure the coil/ICM plug is actually plugged in and tight. If you do see spark then make sure that wire is plugged back into the opti really well for the best connection and insure the harness that plugs into the opti is well seated too. Try all that and come back.
Old Jun 16, 2005 | 09:20 PM
well i pulled the coil wire off of the opti and turned the car over, and it was firing there, well i pulled one of the spark plug wires off of the spark plug and there was no fire there, does that mean my opti spark is dead?
Old Jun 16, 2005 | 10:53 PM
69gto96z's Avatar
If the spark plug wires are crossed, the motor will never fire, because it will knock the timing out, it will be trying to send a spark to the wrong cylinder at the wrong time.
Old Jun 17, 2005 | 12:42 AM
MEAN LT1's Avatar
If all else is hooked up corectly, Your ropti is blown if your not getting a spark from the plug wires but you are getting spark from the coil wire.
Noenav
Mar 1, 2019 07:38 AM
DetroitZ28
Feb 13, 2015 07:33 AM
Noenav
Dec 6, 2014 07:35 PM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
