No Start, no power to coil
Old Dec 9, 2009 | 02:47 PM
  #16
asia517's Avatar
Where should I go from here?
Old Dec 9, 2009 | 04:22 PM
  #17
Guest47904's Avatar
Guest
What is your problem more specifically than "won't start"?
Originally Posted by asia517
I checked the pink wire going to the coil for power and got nothing, where do i go from here???
I went back and tested terminals "A" and "D" on the ICM harness and got 10v DC at both, I also tested terminal "B" on ac scale while cranking the motor and got between 1 and 3 volts ac. which according to shbox's website is good. What Now?
is this the pink wire test? or do I have to take the coil harness off and check the pink wire there?
First of all if you didn't have voltage at the coil, you would not have voltage on the A and D terminals of the ICM. So other than the fact that you are measuring 10 volts, you have NO problem. You can't have voltage on the ICM terminals A and D and NOT have voltage at the coil. It's impossible.
I suggest you check spark at the coil.
Old Dec 9, 2009 | 04:40 PM
  #18
asia517's Avatar
check spark by pulling the plug from the coil to the opti out of the opti and look for spark?
Old Dec 10, 2009 | 05:26 AM
  #19
Guest47904's Avatar
Guest
You need to connect a "known good plug" to the coil
What ever way you need to do it. I would use a plug wire simply plugged into the coil and a plug connected to it. Be sure the plug is touching a good ground point. Don't use a fouled plug.
Then I want you to measure the voltage across the battery with the same meter you claimed you only have 10 volts with earlier.
Old Dec 18, 2009 | 05:42 AM
  #20
Guest47904's Avatar
Guest
Any up date???
We were just wondering if you gave up
maybe2fast
Feb 5, 2015 05:14 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
