No Start on my freshly installed 383, inquire inside
Well Ill bring the motor to TDC cus when putting on the fly wheel on The motor moved a few degree's. Then i installed the opti, so ill bring it to TDC then re install the opti and give it a whril.
Originally posted by gb95zconv
I agree that they most likely did install the gears correctly....but you have to spin the engine up to the compression stroke on #1 before you install the opti.
its either opti on wrong or maybe timing chain is 180 off...it happens to the best. I don't think you clarified weither you were getting spark at all the plugs...maybe you did, but its easiest to double check connections like said and then swap opti and go from there. Rockers would have to be pretty tight to prevent engine from starting....in my opinion...but thats another option...Good Luck
Had the same problem with my car. My rockers were adjusted badly by the first person I had do them which resulted in 9 bent chromoly pushrods!!
The opti was also on wrong (converted mine to the 95+ as well). Like everyone else I would vote for one of those two... I would be willing to bet it is the opti though. Make sure your plug wires are on right too, just to make sure...
From: Albuquerque,NM--5,600 feet above you sea-level cats
Originally posted by BigRick
What?? It doesn't matter where the motor is to put the opti in??? Unless I've done say the last few hundred wrong
im going with the opti on this one. even if its installed wrong you could very well be getting sparks from it so keep that in mind. just take it off and make 100% sure it on correctly. just incase you forget.. you can still fire up the car before buttoning it all up incase that opti is toast
I heard that with 95 vented opti's they they can be put on wrong but how can unvented 92-94 opti's be put on wrong???
COnsidered when you look at the coupling, its keyed one way??
Does it have to do with the splines in the motor that it could be off a tick or 2??
Oncomingstorm22
Jan 22, 2015 07:15 PM
Deadbolt24
Jan 19, 2015 01:29 PM
