No Start condition Fuel pump???
Old Mar 28, 2005 | 12:00 PM
littlbasterd's Avatar
I have a no start i'm thinking it might be the fuel pump. It'll kick over when i spray starting fluid in it but once thats gone it doesn't kick over. when i turn the key on i don't hear the fuel pump power up. anyone have any idea?
Old Mar 28, 2005 | 12:53 PM
sssalah's Avatar
Re: No Start condition Fuel pump???
There's a single wire and conector near the computer that when connected to 12v should start the pump, if that doesn't work, well...hope your tank aint full.
Old Mar 28, 2005 | 09:33 PM
false alarm just a fuse.. checked the fuses its all good now
Old Mar 31, 2005 | 01:43 PM
JC's Avatar
JC
Member
which fuse, I just had this happen to me!
Old Apr 1, 2005 | 07:09 AM
slopokrodrigez's Avatar
In OBDI it's the #5 fuse 15amp. In OBDII it's the #3 fuse also 15 amp. Not sure about a "Y" body though.
Old Apr 1, 2005 | 07:14 AM
JC's Avatar
JC
Member
Its on the 94 Firebird, I bought a new relay and when I installed it, I noticed there is a blue wire running from that #5 fuse down to the relay wiring. The previous owner must have tried to bypass that relay or something. There is a short in the wiring and when I wiggle the wires, the pump will come on. Thanks
Gtpguy
Jan 26, 2015 04:50 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
