NO spark z28 Please help
Old Jan 10, 2012 | 04:42 PM
  #76
faqz09's Avatar
Re: NO spark z28 Please help
http://youtu.be/_IlAJzNQ_w4
Old Jan 12, 2012 | 02:57 AM
  #77
faqz09's Avatar
Do you guy think possibly my intake could be cracked? Im getting only 7 in HG of vacuum and i cant find a leak anywhere and all my vac lines are in the right spot....even tried spraying starter fluid everywhere......
Old Jan 13, 2012 | 08:28 AM
  #78
faqz09's Avatar
I think(not sure) that my timing is off...with piston 1 up the rotor is facing str8 down....i think its supposed to be up to the right a little more, im not sure, anyone can second this hypothesis?
Old Jan 13, 2012 | 10:06 AM
  #79
http://shbox.com/1/opti_cyl.jpg
Old Jan 15, 2012 | 07:51 AM
  #80
faqz09's Avatar
Cool Re: NO spark z28 Please help
Update, finally got it running, problem? Well you guys hit it on the head when you were coming at me about putting on the opti, but I wasnt wrong either. I was putting it on correctly, the problem was whoever had the car before me put the splines in the cam wrong by ONE TOOTH!!! lol, i pulled out the cam gear and hammered it out, reinstalled correctly and shes running like a champ, Thanks guys for all your help and patients.
Old Jan 15, 2012 | 10:41 AM
  #81
There are no "splines in the cam". The splines are formed into the powder metallurgy cam sprocket. But somehow you hammered the splines out of the cam?
http://shbox.com/1/93-94_opti.jpg
Old Jan 15, 2012 | 01:46 PM
  #82
faqz09's Avatar
Ok I stand corrected, I hammered it out of the cam sproket
Old Jan 15, 2012 | 02:33 PM
  #83
You hammered what out of the cam sprocket? The cam sprocket is a single piece? How did you determine that the splines in the sprocket were "wrong by one tooth"? How did you remove the splines? How did you know the correct orientiation to reinstall the splines?
Old Jan 16, 2012 | 05:50 AM
  #84
Guest47904's Avatar
Guest
Let this thread die. You're just prolonging it.
Old Jan 16, 2012 | 04:14 PM
  #85
As far as I'm concerned, this is a troll, and nothing else. Another thread like this and the account won't be active much longer. It's a shame that many of us fell for his BS and wasted out time.
Thread closed.
Noenav
Mar 1, 2019 07:38 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
nophix
Nov 30, 2014 10:26 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
