No spark still
Old May 31, 2011 | 03:44 PM
Bails098's Avatar
No spark still
I still have no spark after doing all tests for opti and coil i have replaced opti with 3 different opti one i know for sure works on another car. 2 brand new coils and 2 brand new icm. I have tested the wiring at the icm. everything reads to what shbox says it should including the white wire which is average 2.5 v ac.
The only things that i can think of not working right are: neutral safety switch, i changed to a B&M hammer shifter around the same time the problem started.
Also i have an aftermarket alarm could this cause no spark even if im getting the 2.5v ac to the icm???
And I have a bypass for the security system there is no security light on but i am also wondering about this causing some problems as well....
I really wanna get this car on the road asap i appreciate any info.
Old May 31, 2011 | 05:07 PM
gatorhead's Avatar
Re: No spark still
The neutal safety switch can be tested easily, just use a paper clip in place of the switch. Are you POSITIVE you have all grounds in place? Actually
If you have 2.5 v AC thats to the connector, the only thing between the connector and the coil is the ICM. Have you tried changing that out with a known working one? Thats the only thing it could be!
Old May 31, 2011 | 08:01 PM
Bails098's Avatar
Re: No spark still
that's the same thing i am thinking, not sure if i wanna borrow one form someone incase my car is shorting them out or something.
Old Jun 1, 2011 | 07:09 PM
Bails098's Avatar
Re: No spark still
Well after getting 2 icm's from part source i got a third from napa and it fired up right away.
Thanks to all who helped out.
Old Jun 1, 2011 | 07:17 PM
gatorhead's Avatar
Re: No spark still
Bad parts right out of the box will make a feller pull his hair out lol! Glad ya got it running!
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
