NO PRESSURE in the RADIATOR...what in the world?
Old Oct 15, 2006 | 02:23 AM
xxsaint69x's Avatar
Ok so i have my car running and today was the first time i took it on a long trip on the highway..after driving for few seconds at 80+ i noticed my temp guage going UP instead of down....it would climb from around 180ish to 193 at max....driving around town at slow speed the temp drops to low 180 high 170s....so after i got to the destination i decided to try to bleed the system, when i cracked it open no air or coolant came out of the bleeder..so i proceded to open the radiator.....there was no pressure in it at all
Car isnt overheating, i am not loosing coolant, everything seems to be working fine..what the heck is goin on, how come the temp is goin up on the highway, and most importantly why am i not seeing any pressure in the cooling system????!? i just got home from driving for 1h and was able just to open the radiator
NO LEAKS AT ALL, AIR DAM IS ON ETC ETC....running a 160 degree thermo stat for a LT1 and a Electric waterpump.....
Old Oct 15, 2006 | 04:32 AM
SS RRR's Avatar
Re: NO PRESSURE in the RADIATOR...what in the world?
I would check the t-stat to see if it's stuck open. I'm also wondering if something funny may be happening with the voltage to the WP...
Old Oct 15, 2006 | 08:14 AM
Check the radiator cap, too.
Old Oct 15, 2006 | 10:09 AM
xxsaint69x's Avatar
how would that have to do with the pressure build up in the system?
if the radiator cap was bad...wouldnt i be able to hear the system leaking steam/air out somewhere?? the weird thing is..there are no abnormal noises or anything
Old Oct 15, 2006 | 11:06 AM
Rent or buy a pressure tester and test the system and the cap. Then, you will know.
Old Oct 15, 2006 | 06:45 PM
xxsaint69x's Avatar
put a new cap on it and it fixed the problem
Old Oct 15, 2006 | 06:49 PM
Awww, I thought you had dismissed the idea of it being the cap.
Old Oct 15, 2006 | 07:54 PM
Jameslt1TA's Avatar
ive been having the same prob, stays around 180 in town but gets up to 220-230 on the highway. Maybe i'll go get a new cap tomarrow.
Old Oct 15, 2006 | 08:17 PM
6SpdLT1Z's Avatar
try a cap... 230 is a bit hot for on the highway, but lt1s run hot.. first fan kicks on at 226 IIRC. I highly suggust a manual fan switch
Old Oct 15, 2006 | 08:25 PM
Josh'95Z28conv's Avatar
Nope. It will bleed the pressure into the overflow tank
Old Oct 15, 2006 | 09:15 PM
SS RRR's Avatar
I was referring more to the temp variance. Glad to see your problem is solved.
Old Oct 28, 2006 | 09:45 AM
xxsaint69x's Avatar
well its not fixed...there is pressure in the system now, but stil on the highway the temp goes up instead of down?!!?! if i slow down to 50-60 it goes down to 17xish and on the highway at steady 80mph+ it will go up as high as 190?!!? WTF!?
Old Oct 28, 2006 | 11:30 AM
Is the air dam on?
Old Oct 28, 2006 | 11:31 AM
Cmr0z28's Avatar
Mine does this as well. Do you have an electric water pump?
Old Oct 28, 2006 | 12:02 PM
xxsaint69x's Avatar
yeah pretty new CSI pump so i doubt that is the problem....i am puzzled by this..didnt have this problem before
KYWes
Jun 14, 2022 06:52 AM
Noct
Jul 14, 2015 01:18 AM
big_mac421
Jul 13, 2015 03:48 PM
whitehooptie
Jul 12, 2015 06:10 PM
asilomar244
Jul 12, 2015 05:53 AM
