no oil pressure!!! engine ticking!! help!!!
Old Jan 14, 2006 | 05:19 AM
  #16
oneslowz28's Avatar
Re: no oil pressure!!! engine ticking!! help!!!
u have my number just call if you run into any problems
Old Jan 14, 2006 | 07:42 AM
  #17
93black-ta's Avatar
the only way to graduate from a novice is to get in there and start tinkering
Old Jan 14, 2006 | 10:30 AM
  #18
LUDA0840's Avatar
Cool Re: no oil pressure!!! engine ticking!! help!!!
im about to go jack up the car and start the operation!!! hope all goes well
Old Jan 14, 2006 | 08:58 PM
  #19
runninfromthelaw's Avatar
ok a few key questions how long did it run when it happened also were you running it hard when it happened.If you shut it off as soon as you heard it then you might be safe.If you drove it for a few min like that then you might have to replace the bearings.But in your case if you didnt run it long do the thing I recomended and you will save a lot of money.You dont have to do open heart surgery just yet.but if you have to drop the pan you have two ways to go about it.
drop the k-member and then drop the pan or try to pull the engine up to get to the pan.
droping the k-member I think is easier.
Old Jan 14, 2006 | 11:10 PM
  #20
ACE1252's Avatar
Just be sure and have a decent torque wrench and some type of factory manual with all the engine's torque specs.
If you have a digital camera, take plenty of pictures before you start. If you don't have a digital camera, buy a cheap 2 or 3 megapixel camera.
Label wire connections, hoses etc....1 to 1, 2 to 2 etc.
The above quote is nothing but the truth. Don't be afraid. Just take your time. Hehe, just don't get mad like me because it's so tight around these cars sometimes.
Old Jan 15, 2006 | 09:30 PM
  #21
LUDA0840's Avatar
well its a spun bearing so im just going to rebuild it and get a cc306 cam in there with some ported heads. all this will be done in the next 2 wks. hope i dont break my 10 bolt!!
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jessie4tin
Jan 7, 2015 08:53 AM
jayblev95
Dec 1, 2014 06:55 AM
Jul 4, 2005 05:00 PM
