No OIL PRESSURE!!
No OIL PRESSURE!!
I went to start the car erlier and found that I had no oil pressure, so I pulled the valve cover and turned it over to see if there was any oil getting to the top of the motor...NOPE!!!
The motor suposidly only had 40,000 miles on it, and it was very clean looking when I got it, It was out of a 97 firebird... I guess Im gonna have to go see if maybe the pickup maybe just fell off, which I hope it is something that simple...
Probably not though, with my luck..
How can you tell if the pump is bad when I pull it and that its not the oil passageways clogged or something??
How long has it gone w/o oil pressure? If it was more than a few minutes (heck even just 30 seconds) you could have also done more internal damage, even after you get the pressure problem fixed, provided it is the pump/pickup assy.
Stroker time
hope you can afford it
Stroker time
Good news! I did a little more investigating and was told to give it a little more time to let the oil get flowing, because of the low volume pump.. so after about 40 seconds or so I reved it up a couple times, and its working just fine now.. started spitting oil through the pushrods. I think I need a new oil pressure switch though.. unless i forgot to plug it in..
before i blew my engine up the oil pressure had been iffy
a little low when starting good during acceleration but it would drop to red and zero if i hit the brakes hard. i thought it was the new sensor i had put in but it was my pick up. it had fallen out of the pump and was just laying in the oil pan
. i heard a clang when i turned the motor over on the engine stand and i thought it was a part of the piston i put a hole in but it was my pick up assembly. so if yours fell off you would still have some pressure just not a lot.
I sending unit is broke...I took the valve covers of to see it was getting oil to the top (poured oil in the head just incase) and then started it and didnt see anything for a while then about 30 seconds in or so it started spitting out the pushrod..
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
