no heat and cooling fans dont work
Old Dec 12, 2006 | 02:12 PM
jalep22's Avatar
Angry no heat and cooling fans dont work
I just replaced my water pump and now I have no heat and cooling fans dont work. Also my car over heats. I put in new water pump, new thermastat and new temp. switch so whats the problem please help
Old Dec 12, 2006 | 02:32 PM
95LT1conv's Avatar
did you thoroughly bleed the system?
Old Dec 12, 2006 | 02:35 PM
bingo's Avatar
Happened to me when I put a new thermotat in. I kept bleeding it and it burped out some air and the temp dropped and the coolant level dropped. I topped off the coolant and it was fine. I am guessing you have air in the pump preventing the CTS from getting a good reading.
Old Dec 12, 2006 | 05:02 PM
jalep22's Avatar
yeah, I bleed the system and still have this problem and would air in the system not alow the fans to come on and no heat. I know the thermostat is opening.
Old Dec 12, 2006 | 05:04 PM
Was the t'stat the one specifically required for the LT1, not the generic SBC model?
Did you put the water pump drive shaft back in correctly?
Old Dec 12, 2006 | 05:06 PM
Jlo's Avatar
Jlo
maybe the relays not working
Jan 23, 2015 01:13 PM
ChrisFrez
Jan 18, 2015 08:05 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
cristian1311
Nov 23, 2014 02:22 PM
Jul 4, 2005 05:00 PM
