nitrous pistons
Old Aug 20, 2008 | 01:24 PM
whyrun's Avatar
nitrous pistons
Ok guys this has been beat to death i'm sure but I'm going to post it over in the N20 section also. I'm figuring out my build and I'll list where I'm at and going to try and give the clearest picture I can..
383 splayed main caps plus gridle using a compustar crank 3.750 H-beam rods shooting for a 12.0 +/- comp on a zero decked block with a set of le3 or AI heads haven't decided yet.
Pistons??? Thought Mahle were good but I'm going to put at least 200hp of hose in it with a max being 300. After searching the forum I can't really find anyone recommending these so then I thought about SRP but to much silca in them afarid I'll split them in half, so what would my next good "nitrous" piston be without busting the bank wide open..
I'll work out a custom grind cam for the nitrous with who I land on for the heads.. It going to be a full weight car auto with a 4k stall and 3.73 gears and all the other goodies that come along with it. Its not a DD but will see street time going to cruise in and what not Its not going to be beat to death everyweekend at the track but I will drop the hammer hard on it when I need to... Probaly said to much but the pistons are whats stumping me right now If anyone has a similar setup or experence let me know thanks for you time and input
Old Aug 20, 2008 | 02:05 PM
ulakovic22's Avatar
I've always been a fan of Wiseco pistons.
Old Aug 20, 2008 | 03:24 PM
seawolf06's Avatar
I've been told Diamond or JE, IIRC.
Old Aug 20, 2008 | 04:15 PM
slomarao's Avatar
JE, Ross, Diamond.
A big part of it is the ring gap.
Old Aug 20, 2008 | 05:17 PM
whyrun's Avatar
well I thought diamond too but they don't have a -5cc piston is only rated to 150hp for nitrous , Ross pistons will blow that bank But I haven't look that hard into the JE's
I'm really not looking for a custom piston I want something off the shelf its got to be out there
Old Aug 20, 2008 | 05:42 PM
rskrause's Avatar
Moderator
http://www.kennedysdynotune.com/Nitr...ech%20Tips.htm
Authored by yours truly.
Rich
Old Aug 21, 2008 | 06:46 AM
tomcowle's Avatar
Call NOS Nelson at Arias Pistons, they make a great slug for the juice.
Old Aug 21, 2008 | 07:13 AM
jasonisdn's Avatar
i went with some custom diamonds, hit up eric at vre, he has my specs from diamond. since his business is right down the street from them.
Old Aug 21, 2008 | 07:58 AM
whyrun's Avatar
What did those custom slugs cost?
Old Aug 21, 2008 | 12:43 PM
jasonisdn's Avatar
5 something with mini domes cut into them
Old Aug 21, 2008 | 12:54 PM
ghost97ta's Avatar
i have ran je pistons on 275 shot for 4 years
Old Aug 21, 2008 | 12:58 PM
Nostang 96z's Avatar
I chose diamond nitrous pistons on my build. I am building a similar combo and spraying a max of 250. My pistons were custom for my combination and were matched to obtain the compression I needed. I had my pistons in less than 6 days including shipping time from the time I placed my order. The pistons look great and I would recommend the company to anyone. Talk to Nick D'Agostino he will hook you up. Although, I would buy my heads first and estimate what head gasket you are going to use before ordering to get the desired compression ratio.
BTW, the pistons, plasma moly rings, pins ,clips etc were $1062 shipped.
95blkss
Sep 22, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
