NGK recommendation
Old May 11, 2005 | 03:58 PM
Jeremy_30th's Avatar
Question NGK recommendation
NGK recommended the TR6IX for my setup no juice/blower just n/a on built top end. Around 12.3:1 static compression. I think one colder and close the gap about .005 should fit the setup or atleast be a good start. What do you think?
I heard raising the comp calls for colder tighter gaps but I dont know of anyone that has done it
NO plans for spray soon either Thanks for your comments
Old May 11, 2005 | 04:18 PM
FIREHAWK #7's Avatar
Re: NGK recommendation
ive had nothing but bad luck with NGK's ... both TR6 and TR55's.... they had a crack in them, car started throwing misfire code..... just stuck with the AC delcos....
Old May 12, 2005 | 03:17 PM
Any comments suggestions? Does this seem right to go 1 colder with my setup? And should I tighten the gap.005 or so?
Old May 12, 2005 | 06:13 PM
sssalah's Avatar
The heat range seems ok with the high compression. The stated gap is too tight, stock gap is 0.05" and TR6 gap as I recall is 0.035".
Old May 24, 2005 | 08:16 PM
TR6IX are in gapped @ .045 and wow, the plugs I had before must have either been junk or really just not right for my setup.
#1 It pulls alot better
#2 I got another 20-30+ miles to a tank.......NGKTR6IX
Old May 24, 2005 | 08:23 PM
80TA's Avatar
These are the iridium plugs one heat range colder? Wonder where I can buy them. I woudl think they would still be ok for nitrous use..platinum is not supposed to be good but iridium is supposed to be fine for turbo use.
Old May 24, 2005 | 08:26 PM
Yup one heat range colder than stock. They are actually recommended for boost or spray. I think what helps is the electrode its not like normal ones its like a needle and I guess they require less of your ignition and provide a better sparK.
Beave2780
Sep 23, 2015 12:37 PM
tommalcolm
Sep 11, 2015 03:39 PM
Schul365
Aug 25, 2015 05:47 PM
Slayer
Aug 17, 2015 03:55 PM
BMX Dad
Aug 15, 2015 01:15 PM
