Next Mod Opinion
Old Mar 13, 2003 | 12:20 AM
  #16
texasTA's Avatar
I would say some good tires + some launching practice or some used shorty headers. Either will get your time down some.
Old Mar 13, 2003 | 12:39 AM
  #17
bachehbad's Avatar
what are some good long tube headers? and hopw much do they go for new??? And you guys say i'll gain 20HP with these??
Old Mar 13, 2003 | 12:50 AM
  #18
scottslt1z28's Avatar
flp makes some really great long tube headers........but they are pretty pricy................if you wanna know more about them....go to........www.thunderracing.com.........they sell them
Old Mar 13, 2003 | 12:51 AM
  #19
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
FLP's or Hookers are really good. You will get a good 15 to 20 RWHP from them. But the only disadvantage is you will most likely not pass emissions. But that is not a big deal here in texas for me so i would be fine with longtubes. I think he should save his money up for a GOOD set of longtubes. Then so some 4.10's in a moser 12 bolt like im gonna do. Cause i would not trust our stock rear end with DR's. But of course thats just my opinion.
Chris
Old Mar 13, 2003 | 01:29 AM
  #20
smokindastangs's Avatar
Why would he not pass emissions?
Old Mar 13, 2003 | 01:49 AM
  #21
Most guys with long tubes dont pass emissions. Just ask most of the guys on the board and they will tell you the same thing. Long tubes give you power but you sacrifice that power for emissions. Somebody chime in and support me with this because i know its true. Thanks. No disrespect smokindastangs Thats just what i have learned in my experience on the board.
Chris
Old Mar 13, 2003 | 01:59 AM
  #22
bachehbad's Avatar
Yea i dont understand the emmisions thing either? does getting longtubes make you burn more gas just regularly driving?!?
Old Mar 13, 2003 | 02:31 AM
  #23
hsyr's Avatar
Longtubes move your cat from its origional position. If you have emissions in your area chances are that relocating the cat from its stock position will automatically cause you to fail. I'm not totally sure on this tho cuz I have no emissions here
Old Mar 13, 2003 | 03:07 AM
  #24
chesee48's Avatar
Yep he just said it. It moves your cats. Only solution is FLP which is hella expensive
Old Mar 13, 2003 | 07:34 AM
  #25
tetsuo97z28's Avatar
Thanks everyone for the replies...
Sorry I should have included my gear ratio in the first post.
Currently I have 3.23's installed at the moment.
I would like to go with headers but finding a used set to bolt up to the factory y pipe is going to be hard....
But gears are going to run my into the 500 range, because Ill need to recalibrate my PCM for 3.73's.
So It looks like DR's are going to be my best bet.
When I ran the 14.0 I launched the car @ 1100RPM's.
BTW Does anyone have any used headers or other parts for sale that will help me???
Thanks everyone for the replies.....
Old Mar 13, 2003 | 08:46 AM
  #26
max929's Avatar
Originally posted by Draco
You could also try an electric water pump. Only about 5-10 hp but for the price it's actually a pretty good hp/$ ratio
I don't see gaining 30hp with headers on an otherwise stock motor.... maybe 20hp with longtubes and 10-15 with shorties on the stock heads/cam.
I wouldn't bother with a new TB until you are in the 350+ rwhp range, unless you find a killer deal.
If you really wan't to get into the 13's at all cost go with gears and/or drag radials.
I disagree with finding 5 to 10 hp with electric water pump.
Maybe 1hp if that.
Old Mar 13, 2003 | 09:28 AM
  #27
93Z286Speed's Avatar
me = not long tubes
Illinois = emissions ******
electric WP wont give you 5-10 at the rear.. mabey at the flywheel
Shortys will still make more power...not as much as LTs unless you go with AS&Ms but those are expensive
Old Mar 13, 2003 | 10:03 AM
  #28
chesee48's Avatar
Originally posted by 93Z286Speed
me = not long tubes
Yep or Rksports are basically the same thing as the AS&M..
Mac's are good IMO for the price.
Old Mar 13, 2003 | 10:31 AM
  #29
i like SLP stuff.. so ima go with SLP shorties and ypipe
Old Mar 13, 2003 | 11:43 AM
  #30
Draco's Avatar
here you go guys,
eletric pump = 6 rwhp on this car.
http://ws6.com/mod-14.htm
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
DelSoto
Sep 19, 2015 05:31 AM
