New Walbro Fuel Pump Installed....
Old Aug 11, 2012 | 11:07 PM
  #16
skibbe_96z's Avatar
Re: New Walbro Fuel Pump Installed....
It doesnt take very long at all to remove the pump and check all the connections and I was planning on changing out the fuel filter (which doesnt take time either) so I figured I might as well do that before I run the fuel pressure test.
Now that I have run the test, I will get a new pump sent to me and hopefully it works this time around. Once I pull it from the bucket, I will see if it has the Walbro stamp and made in USA stamp to make sure it isnt a Chinese counterfeit and I will talk to High Flow Fuel and make sure it is a legit Walbro. Thanks for your help guys and I will let you know when I get the new pump in and hopefully a running camaro!
HarleyZ28
Oct 5, 2015 06:23 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
Scottyboy
Feb 11, 2015 10:28 PM
ANDYZ28
Dec 29, 2014 09:13 PM
