new track numbers, good??
Old Aug 7, 2003 | 07:39 PM
tealdevil's Avatar
Unhappy new track numbers, good??
after installing the hot cam kit and 3.73 gears, i took the car to the track yesterday, this is my best run:
R/T .291
60' 2.267
330 6.186
1/8 9.374
MPH 76.69
1000 12.151
1/4 14.485
MPH 97.30
the weather was:
Temp F. 78
Barometer 23.41
that was at Bandimere Speedway in Colorado
thanx in advance..
Old Aug 7, 2003 | 07:48 PM
Robert95z's Avatar
Anything but good!!
Even without tuning it should not be running that slow.. something is wrong
Old Aug 7, 2003 | 08:07 PM
1994CamaroZ28's Avatar
Something has to be wrong, stock lt1's run between like 13.8-14.5
Old Aug 7, 2003 | 08:30 PM
revtime's Avatar
Check out the track he was at guys.
sixty foots could be improved but I don,t think its that bad for the track you were at.
Bandimere is near Denver isnt it? Thin air up there.
Old Aug 7, 2003 | 08:32 PM
Robert95z's Avatar
His mph should still be higher than that
Kevin97ss's Avatar
If the Baro. you supplied is not a misprint then I would say the numbers are ok. That is some really thin air. A bad day here in Jersey is low 29's.
Old Aug 7, 2003 | 08:35 PM
brain's Avatar
Do you have any stock numbers to compare to? Colorado is up there, but I would expect the car to run anywhere from 108 - 112 with a hotcam kit, and to take away at least 11 mph is alot for air. I would haphazardly guess the car should be running 14.0s at 100 at least. If you know the DA there, I think you can do a correction for what it would be at sea level. That might help to compare as well.
Looked up elevation for Bandimere. 5830 ft. Corrected to sea level using http://www.rfedd.bigstep.com/generic.html?pid=97 this as a corrector, it is equivalent to a 13.4 @ 104.8. I would expect a bit more from a heads/cam car, but the correction isn't necessarily 100% accurate.
Old Aug 7, 2003 | 08:38 PM
Rodrigues's Avatar
Thats a lil optomistic.... I get 109.27 mph with ported heads/xe224 cam and longtubes.
Old Aug 7, 2003 | 09:02 PM
tealdevil's Avatar
i ran 15.0 the last time with almost the same condition.. that was before the hotcam kit and 3.73..
but the problem is that this is with the tunning.. not major tunning, but just simple one, there is lot of white smoke.. and when the car is on drive it idels at 600.. and when u crusing at 1800 rpm u can feel the car kind of hesitating..
what do u think wrong...
Old Aug 7, 2003 | 09:07 PM
revtime's Avatar
All right, maybe I was a bit premature to think it was not that bad.
Bandimere is still thin air but have you had any tuning done besides the HPP?
See if you can get someone familiar with your area to tune it for you. Maybe a dyno tune in your area so it will be tuned in the air you will be running in.
Maybe see if you can get a scanner on it and see what the comp is doing.
Old Aug 7, 2003 | 10:18 PM
Kreinmc's Avatar
Perfect example of what i have seen from just about all of the XE cammed cars. The XE cams seem to just blow in these cars. That is ridiculously slow for heads/cam unless you are also in Denver.
Old Aug 7, 2003 | 11:10 PM
turbo_Z's Avatar
i hope you are kidding. the XE224/230 isnt that much larger than the hotcam AND he has home ported heads. 109 mph is really good if you ask me, especially with heads that probably dont flow more than unworked LT4 castings.
Old Aug 8, 2003 | 03:27 AM
97bowtie's Avatar
See sig - stock heads, stock tuning in the heat of AZ. I STILL haven't seen good numbers out of the XE grinds.
Old Aug 8, 2003 | 03:57 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
if your blowing white smoke... your burning coolant/water... head the head gasket....
Old Aug 8, 2003 | 06:10 AM
CANTONRACER's Avatar
In good weather at sea level, your car would be running low 13's@106-107 MPH.
