New timing chain with cam upgrade?
Old Feb 4, 2004 | 11:24 AM
  #16
CMGETSM's Avatar
Alright I just got my kit. Reading the install instructions it says that a Heavy Duty Timing Chain Set is mandatory for engine operation above 5500 rpm. I don't think I'll be above that. What is the stock fuel cut off/rev limit on an LT1?
Old Feb 4, 2004 | 11:31 AM
  #17
Compstall's Avatar
The stock rev limit is ~ 5,700.
BTW, I already have a CSI water pump in the mail now.
Old Feb 4, 2004 | 01:22 PM
  #18
ibanez6rg's Avatar
So if you decide to do the conversion, the LT4 HD would be your only option.
Old Feb 4, 2004 | 03:06 PM
  #19
speedmiser's Avatar
Originally posted by Newbie97
You dont want to do that. For the cost of a new opti and the ex duty chain. Just get a cloyes double roller and a csi pump and you want have to change the opti. and you will probably save $100 or so and free some hp up with the electic h2o pump.
NO, NO, NO....
To run a double roller in the 93s and 94s you must do the opti converstion.
Same goes with the LT4 and ED chain sets.
None of these sets have a cam gear that's keyed for the shaft that drives the non-vented opti. (Well, I imagine you could find a machine shop to modify the cam gear to possiblly work, but I'm sure it would cost more than doing the vented opti conversion.)
Unless you're willing to do the vented opti conversion on the 93s and 94's, the only options are the stock replacement set and the Lunati set. And the Jury is still out on whether the Lunati set is any better (or actually worse) than the stock set...
Old Feb 4, 2004 | 03:10 PM
  #20
Mtrhds94Z's Avatar
I say[again ]:
To use a LT4HD [or a Cloyes etc double roller]
You have to change cam, opti, timing cover, and opti harness to 95 style..
Also add vacuum lines for opti..
[This is so whether you use a electric water pump or NOT]
The reason for this is that the early opti's drive with a splined hole in the cam gear... and noone MAKES an aftermarket that drives opti that way..[except Lunati see below]
You cannot run a Cloyes double roller with a 94 opti...period...
There IS a Lunati set that will work with a 93-4 opti, but it has had very bad 'reviews' I wouldn't use one..
Old Feb 4, 2004 | 03:47 PM
  #21
speedmiser's Avatar
BTW, the Lunati set is not a roller set - it's a linked belt, similar to the stock GM set.
I agree, I wouldnt try it either...
Old Feb 4, 2004 | 04:23 PM
  #22
Originally posted by CMGETSM
Will this really work? Do you know of anyone who has done this? What other parts are needed, and where to get them?
thanks.
No, it won't work. Bad suggestion. The Cloyes set will not turn your splined opti. If you intend to use the non-vented opti, you are stuck with a stock type cam gear.
Old Feb 4, 2004 | 04:24 PM
  #23
ibanez6rg's Avatar
Yes, say no to Lunati!
Old Feb 4, 2004 | 11:12 PM
  #24
CMGETSM's Avatar
Thanks for all the input everyone. I've decided that if the chain set looks good then I'm going to leave it, but if not then I'll get a new stock set.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
