New times with crane 210/224
1.86 60'
8.096@87.33 1/8th
12.561@111.00 1/4
This was with a slipping transmission. It bounced off the limiter 3 times at the top of 1st before it finally shifted, and almost hit the limiter at the top of 2nd shifting a few hundred RPM's higher than it should, so there's definatly a lot left in it. It was also only in the mid 70's so once if finally cools down here and I fix my transmission it should really cut some great times. I'm also still on the stock torque convertor.
8.096@87.33 1/8th
12.561@111.00 1/4
Re: New times with crane 210/224
Thanks for posting the info. Looks like a great time to me. Glad to
see the baby cam can put some numbers down. I was hoping that
I could get into the 12s with the 227. Now if can just solve my
ignition problems.
ignition problems.
Originally Posted by brandboZ28
Nice times. You need a stall converter and youll be flying!!!
A guy that ran a 12.0@112.8 in the winter down here was only runnin 12.38-12.4's@109mph last night, so with a convertor and built transmission it will really wake up.
From: Austin, TX or Texas State University at San Marcos
Are those numbers in your sig on a Mustang Dyno?? They are very similar to what I put down on a mustang dyno. Just curious.
Chris
Chris
Chris
Chris
Nitto 555R drag radials. The first run I only did a couple second burnout and spon all through 1st, so I heated the hell out of them for my 2nd run and dead hooked. I didn't bother to try to get any more runs in since the transmission is going and I figured I shouldn't be makin anymore passes on it. Hopefully I'll find the money to get it fixed and throw in a nice 2800 vig before it heats up again down here in florida.
Originally Posted by Makaveli
very nice, what tires were you running? what are your rpms while crossing the traps with those 373's?
oldschool
Feb 9, 2016 09:21 PM
