New Times on 224/230 XE
Old Apr 17, 2003 | 03:30 PM
  #16
RichJ's Avatar
Originally posted by ZZtop
Rich and Untamed, I noticed yall are from VA and Illinois. I was wondering if either or you have passed emissions with that cam? Also, i know that a higher lsa reduces emissions, but how does it effect performance?
I have passed emissions in Northern Virginia (treadmill two speed test) with Hooker LTs and dual cats, and have a friend with the same cam who has also passed in Northern Virginia. But I've also heard of people repeatedly failing when the cam was ground on a 112 LSA. If you are worried about emissions, I'd stick with the 114 LSA version. The car has a noticeable lope even with the 114 LSA. In general, the wider LSA will spread the power band out so that it makes better power way down low and way up high, but it's weaker in the midrange. The 112 LSA would make a better street cam because its torquier, but I don't think you lose much at the strip with the 114 LSA.
Old Apr 17, 2003 | 03:34 PM
  #17
RichJ's Avatar
Originally posted by ShelbyZ28
Do you have stock heads with this setup? I want to do this cam but I want to keep my heads stock for now. What are you guys opinions on this. I know guys have CC306s with stock heads so this cam should work to right? Thanks
Bryan
I have ported heads. I'm sure the car will run fine with a 224/230 and stock heads, but I don't think you'll gain much if anything over a 218/230 except worse drivability and a choppier idle.
Based on what I've seen in other people's cars over the years (I've had this cam for 3 years), I'd go CC EE 218/230/114 in a stock headed car and CC EE 224/236/112 in a ported head car (assuming you're not worried about emissions or low speed drivability).
Old Apr 17, 2003 | 03:38 PM
  #18
ShelbyZ28's Avatar
Thanks for the info Rich. Good luck with your car
Bryan
Old Apr 17, 2003 | 07:06 PM
  #19
unTAmedLS1's Avatar
I cant wait for gears and some drag radials. Plus I will be needing a tune soon because I just got an emission notice in the mail somehow I thought I was exempt
Old Apr 17, 2003 | 07:18 PM
  #20
LT1ponykilla's Avatar
Good times man.
You know there are people running low 12's with just bolt ons and DR's. Also a little weight reduction thrown in there.
Old Apr 17, 2003 | 07:21 PM
  #21
xxsaint69x's Avatar
hahaah
Maybe my car is a freak I am goin to dyno it in few weeks....we shall see what that thing makes
Marcin
ps. my secret is...4.11s and CC306...grab the ***** and let that pummpy sing to 7k jk....i shift around 6500ish
I guess i am always in the awsome power band of CC306..my car screems up top.
  #22
jonaddis84's Avatar
Man, I was happy to hear that with my MPH I could run mid 12s with a 1.8ish 60ft compared to the 13.2 with a 2.3. But now Im a little dissapointed that you ran that good with a 2.3 60ft, maybe if I could hold on to the gears longer (6500 rev limiter) I could pull into the 12s right now.
Old Apr 17, 2003 | 07:24 PM
  #23
jonaddis84's Avatar
Oh, by the way, forgot to say killer times man, congrats.
Old Apr 18, 2003 | 03:23 AM
  #24
unTAmedLS1's Avatar
Thanks man I think the key is that my car has no options and its a formula. I have no airbags, no ac, no sparetire, aluminum driveshaft, no air or egr, no power anything. Plus I only weigh 130 so its pretty light.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
