New TB, quick question
Old Nov 24, 2007 | 04:58 PM
95z28man's Avatar
If I plan on doing the TB bypass with my new TB, do I need to transfer the old bottom piece with the coolant tubes attached? It has a sensor on it, so I'm thinking I will have to, but I wanted to make sure.
Old Nov 24, 2007 | 05:23 PM
The Engineer's Avatar
Remove the hose from the TB that comes from the radiator and connect it direct to the cross-over metal tube on the passengers side valve cover. You need to maintain that coolant flow. That is the most simple and easy TB bypass.
WD
Old Nov 24, 2007 | 05:55 PM
speed_demon24's Avatar
The IAC is on that so yes.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
