New Opti wont start??? ....??
Old Jan 26, 2011 | 06:24 PM
PonyEater8788's Avatar
Put a new opti spark in it turned it over ran great everything was fine. Noticed the water pump was leaking so i shut it down. So i tore it all down again sent the opti back had a warranty on it got the new one and now wont start. I checked all of the wires made sure everything was connected. Any ideas as to what would cause this?
Old Jan 26, 2011 | 06:44 PM
my1994z28's Avatar
Re: New Opti wont start??? WTF??
Double triple check all wires,coil wire,opti connector,etc
Old Jan 26, 2011 | 11:08 PM
What year is your car, so we know which type Opti you have.
Are you sure you have the drive mechanism aligned correctly (splined shaft or dowel pin, depending on which Opti you have)? Have you checked the harness connector for corroded or damaged pins?
What brand? Some of the cheapies fail out of the box. Did you loc-tite the screws that hold the rotor on?
You need to add a "Signature" with basic info about your car - year, model, engine, trans and major mods.
Old Jan 27, 2011 | 07:12 AM
ptown's Avatar
When I did mine I thought I had connected all of the wires back up. It turned out I missed one of the ground wires that i had disconnected.
Old Jan 27, 2011 | 12:11 PM
FastandBlue's Avatar
Re: New Opti wont start??? ....??
Is it even turning over? Have you checked for spark while turning it over?
Old Feb 2, 2011 | 09:04 AM
2cub49's Avatar
Check the 10 amp ignition fuse that's under the hood on the driver side fuse box.
I put an opti in and the car cut out after idling for a minute and wouldn't start.
Turned out to be this fuse.
Old Feb 2, 2011 | 12:32 PM
He hasn't been back to the site since his original post.
Sergio
Jan 27, 2016 04:27 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
ChrisFrez
Dec 7, 2014 06:01 PM
