new opti and coil ..... problem still there
Old May 5, 2005 | 08:57 PM
stanley's Avatar
Ok I had a new opti spark along w/ plugs and wires put in around 4 thousand miles ago and here latley it has started to idle rough so i replaced the coil and that fixed that. Now it is missing and cuttin out in the upper rpms just like it did when the opti was out. After the opti install and up till tongith it has ran fine except for the idle. Does anyone know what the problem may be? help me ASAP!!!!!!!!
Old May 5, 2005 | 09:01 PM
Bersaglieri's Avatar
Re: new opti and coil ..... problem still there
Mines always had kind of a rough idle, even after I did my opti. I am not sure what it might be, burnt plug wire?, IAC sensor? Were you driving your car to close to water? Mine starts to act up when I hit puddles.
-Dustin-
Old May 5, 2005 | 09:35 PM
stanley's Avatar
no i wasnt' anywhere near water.....its dry as hell here. Could it be fuel related? it was fine b4 the coil install tho aside from the rough idle
Old May 5, 2005 | 09:37 PM
Stock coil replacement or aftermarket?
-Dustin-
Old May 5, 2005 | 09:42 PM
WeirdRich's Avatar
still sounds like an opti problem....water can get in from the water pump to, so when was the last time you checked the weap hole on the pump?
Old May 5, 2005 | 10:00 PM
stanley's Avatar
water pump was replaced w/ opti............but why would it start doing it when i changed the coil?
grabbem88
Mar 18, 2015 01:25 PM
maybe2fast
Feb 5, 2015 05:14 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
