New Oil Pump
Old May 11, 2011 | 11:59 AM
Z28-50's Avatar
New Oil Pump
OK, so it started as a clutch replacement then progressed to a rear main seal and oil pan gasket replacement.
The pan is off, thinking I should replace the oil pump with a 10554 melling.
Engine has 80k
Best method to prime the pump without pulling the intake?
Old May 11, 2011 | 12:17 PM
RamAir95TA's Avatar
Re: New Oil Pump
Pull the intake.
No seriously, that is the BEST method. Many people have no problems disconnecting the injectors and letting the starter spin the shaft, but during that time you have zero oil pressure. Call me a worry-wart, but why take the chance?
I would also venture to say that replacing the oil pump would be a waste of money, since they hardly EVER go bad by themselves because they are the most lubricated part of any engine. I honestly wouldn't mess with it.
Old May 11, 2011 | 07:27 PM
96capricemgr's Avatar
Re: New Oil Pump
The stock oilpump is probably the most reliable you will find. I might consider some casting cleanup or a higher pressure spring but not replacement.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
