New Oil Pan gasket?
Old Apr 24, 2005 | 01:08 AM
eagleknight97's Avatar
New Oil Pan gasket?
Im pretty sure im gettin a little leak from my Oil Pan gasket, but am not totally sure. I tried out of synthetic oil a few changes ago, and then devolped a leak. So now I think that the gunk that had built up to keep a leak from developing, is gone. How hard is it and is it worth it to replace the oil pan gasket? It doesnt drip much, only a few small drips every few days, not enough to even make me add oil ever between changes. Also, if I did it, it would be when I was doing headers, so I wouldnt have to worry about the exhaust system being in the way.
Old Apr 24, 2005 | 02:01 AM
ajschult's Avatar
Re: New Oil Pan gasket?
ok, so i am not sober right now, so excuse my typing. but basically to do a oil pan gasket install isnt too hard. when i did mine i didn't drop the oil pan off of the car. instead i removed all of the oil pan bolts and it dropped a few inches. after removing the old gasket i cleaned the oil pan surfaces and the bottom of the block as best i could. then i slid the new gasket around the oil pan and was able to manipulate it enough to get it into place and then bolt the pan back into place. i would recommend that you use some rtv sealant around the back of the oil pan and where the timing chain cover ties into it. hope this helps....
Old Apr 26, 2005 | 11:14 PM
littlbasterd's Avatar
Gm controlled sepage...deal with it
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
