New motor, one trouble code, help!!!!!!
Old Sep 18, 2008 | 09:48 PM
ascastil's Avatar
I need to know if the DTC P0506 is related to my new BBK TB. I read on Alldata that a vacuum leak could be a poosibility, the only thing I can think of would be my intake manifold, but I have not checked that yet. There are no cats on it yet, the TPS voltage checks out, everything is brand new. PLEASE help, I am thrilled this beast is running, just want some help ironing out the bugs.
Old Sep 18, 2008 | 09:52 PM
mrmint69's Avatar
You should add the year of your car and if its a stick or auto. It sure sounds like it might be. Did you check the throttle blades to see if they are set right. I see a few problems with these until they are setup right.
Old Sep 19, 2008 | 12:45 AM
ascastil's Avatar
97 z28 A4. I have a scan tool at work and the TPS voltages are in the ballpark, but i didnt post that the idle is at 1000 rpm on the dash, cant rememeber what it is on the scantool. Should I attempt to adjust the blades if the voltages seem ok? And I have read on this forum about having to open the hole between the butterflies and vice versa on the BBK's cause they were already there?!!
Old Sep 19, 2008 | 05:32 AM
PLEASE don't post the same question twice. I just spent time answering your original post, only to find that you had a second post with the same question. Not a good idea.
Might also want to add a "signature" with the basic info about your car, so people don't have to ask you about it every time you post.
armedtrigger
Feb 24, 2015 08:30 PM
jayvar
Feb 2, 2015 10:00 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
