New (to me) 94 Z28 running Rich
Old Jun 11, 2012 | 10:55 AM
  #16
koden's Avatar
Re: New (to me) 94 Z28 running Rich
Are there separate temp sensors for the ECU and the Gauge on our cars? The car is running like it is in cold mode. My temp gauge reads between 170 and 180 but I think most vehicles have separate temp sending units for the ECU and the gauge.
Will the scanning software show if this is the issue?
Old Jun 11, 2012 | 02:53 PM
  #17
mrmint69's Avatar
Gauge is in the side of the engine and the other is in the water pump housing.
Old Jun 11, 2012 | 05:00 PM
  #18
Gauge temp sensor is in the driver's side head, between #1 and #3 spark plugs.
If you put a scanner on the PCM, it will show you the temp reading being fed to it by the coolant temp sensor in the water pump housing.
Courtesy of Shoebox:
http://shbox.com/1/temp_sensor2.jpg
http://shbox.com/1/temp_sensor1.jpg
4th Gen LT1 F-body Tech Articles
Old Jun 12, 2012 | 04:44 PM
  #19
koden's Avatar
Thanks for those links. Great info.
Cable should get here in a day or 2. I'll post back when I have some info from the scans.
Old Jun 14, 2012 | 09:50 AM
  #20
koden's Avatar
I filled the tank up and calculated my mileage again. On this tank I did not drive very conservatively. A little hot rodding, not so gradual acceleration etc. I got 17mpg as apposed to 16mpg when driving very conservatively for a full tank.
The cable gets here today so hopefully I will know more this eve. Maybe a faulty TPS.
Old Jun 14, 2012 | 11:09 AM
  #21
mrmint69's Avatar
There is so much data, its amazing what you can find is wrong with the Datalogs.
Old Jun 14, 2012 | 07:00 PM
  #22
koden's Avatar
Ok, pulled the codes and I am getting:
MALF 48: MAF System Fail
Other than the low ac pressure code thats the only bad code. It's running in open loop because of the MAF error.
Last edited by koden; Jun 15, 2012 at 02:13 PM. Reason: as code was suppose to be ac code
Old Jun 14, 2012 | 07:29 PM
  #23
koden's Avatar
I'm searching through the forums on the error for more troubleshooting info but I measured the voltage and I get 12V on pink and 5V on yellow (MAF connector unplugged and car not running).
Old Jun 14, 2012 | 10:10 PM
  #24
mrmint69's Avatar
https://www.camaroz28.com/forums/lt1...bvious-459571/
Assuming you read this one. Sounds like unless the unit is dead it is something to do with the wiring.
Old Jun 15, 2012 | 02:08 PM
  #25
koden's Avatar
The voltages on the MAF look fine (12V and 5V). I did a 15 min drive yesterday. Half city half freeway and logged the whole trip. I exported it to CSV. If someone wants to take a look at it if can be downloaded here...
Drive 1 log file
I was incorrect when I said the car is running in open loop. It does switch over to closed loop after driving for a bit. Not sure what data bit that is though.
Old Jun 16, 2012 | 12:09 PM
  #26
koden's Avatar
If someone wants to play the actual log file back on datamaster here is the link to download it:
Drive 1 DM File
I believe the reason I am getting DTC 48 was because I unplugged the MAF when the car was running the other day to see if it made a difference. I'm resetting the codes and I'll recheck again today after I drive it.
Do the fuel trims look normal or are those values indicative of an air leak somewhere?
I also noticed the O2 sensors would vary quite a bit from each other. Is that abnormal?
Old Jun 16, 2012 | 03:36 PM
  #27
The .csv link works, but the .uni doesn't.
It goes into closed loop right where it's supposed to, at 206 seconds run time.
Each bank of the engine is controlled independantly. The O2 sensor volts will not be the same, and often not even close in closed loop. When you go into pwer enrichment mode (PE) they will stabilize and they should be close.
A vacuum leak would affect it more at idle and in the low load cells. In Cell 16 (idle) it's actually pulling out a bit of fuel on both banks. Low load cells aren't too bad. The elevated LTFT's (140+) are in the higher loead cells.
Give me some time to look at it.
Old Jun 16, 2012 | 05:06 PM
  #28
koden's Avatar
Doh. I fixed the link.
Thanks for the help. Im out on the boat salmon fishing with the family but ill check in later.
Old Jun 17, 2012 | 12:42 PM
  #29
koden's Avatar
So I reset the computer and took it for another drive and I did not get any MAF codes so the DTC 48 was because I unplugged it while running.
On this drive I got on the freeway and did a couple full throttle pulls in 6th and the car just stumbled (around record 3650 in the logs below).
Drive 2 CSV file
Drive 2 UNI file
Is it normal for the car to tumble wile doing 55mph in 6th giving it full throttle? It also stumbles really bad off the line unless I get the RPM's up a little.
Old Jun 18, 2012 | 11:23 AM
  #30
mrmint69's Avatar
Sometimes the wot stumble are from not enough fuel pressure or not enough voltage from the alternator. Have you ran the car with the fuel pressure gauge hooked up during these runs and how does your voltage look at these times also? Both easy to check and the voltage can be seen on the datalog, but I can't look right now. I would get into the high 10's and low 11's for the voltage readings and it affected my cars performance.
