new lt1 motor mounts
Old Feb 7, 2010 | 04:17 PM
chevyrules85's Avatar
need new ones as mine have 165 k on them. im planning a 396 pushing about 550 fwhp. just wondering what mounts to go with? the poly mounts from prothane? or solid? ive seen the moroso solid mounts, that reuse the motor mount stands, and the madman mounts, that replace everything. i can remember my dads 69 plymouth satellite with a 383 magnum, when you started it, the whole thing shook at idle, the motor shook the entire car and you could see the body torque from the power of the engine. would solid mounts do this, or just create problems for me? any advantages to solid or poly? thanks guys!
Old Feb 8, 2010 | 11:59 AM
n2ceptor's Avatar
Most go with poly...(drilling out the rivets is required) I use regular stock mounts....(I like a smoother ride) Solid is more for the weekend warrior/racing car...(Unless you like being shakened to death)
Old Feb 8, 2010 | 12:20 PM
SweetZRag's Avatar
I went with the poly from Prothane. Definitely transfers more vibrations to the passenger compartment but not too bad. I figure they will last longer than the OEM rubber. Also, I kept tearing the trans mount so I needed the additional stength.
Old Feb 8, 2010 | 01:27 PM
RamAir95TA's Avatar
When I did my 383 build I also switched to polyurethane mounts from Prothane with good results.
Old Feb 8, 2010 | 03:02 PM
i figured most would say poly, but does anybody have the solids? from madman or moroso? any comments from anyone who has those would be appricaited.. would they really be to much for a normal person, are they a track only thing? i just want that feel that the whole car shakes at an idle thanks guys
Old Feb 8, 2010 | 05:29 PM
SnakeOiler's Avatar
If you actually decide to go with stock, let me know. I got a set with about 1000 miles on them laying around.
Old Feb 8, 2010 | 07:37 PM
madhatter's Avatar
I've never driven an LT1 with solid, but have driven SBC cars and LS1 cars with them. I will be going with them when I need to replace them. Installed a set in my buddies 98. His cam is pretty lopey and always shook the motor pretty well. Can barely feel the car running with solids now.
Old Feb 8, 2010 | 07:50 PM
ive heard they transfer more vibrations/shakes into the passenger compartment. im leaning towars the madman mounts, but dont know if they would be to much for me or not...
Old Feb 8, 2010 | 07:56 PM
RamAir95TA's Avatar
If you are even slightly worried about vibration, then don't go with the solid mounts. Poly mounts are a good combination between firm and soft and won't wear out. IMO, solid mounts are race-only (others will disagree but that's okay). Prothane mounts are around $50 from Summit.
Old Feb 8, 2010 | 08:13 PM
yeah, i guess i dont really want virbrations as much as i want to feel what the engines doing. i think i may go with the prothane mounts, there much cheaper.
Old Apr 10, 2010 | 09:25 PM
z28beast's Avatar
ok so my mounts are worn out too. i DONT want crazy vibrations at all!!!!!! im thinking about the red prothane mounts for 50 bucks from summit.. will these vibrate alot or no? also how do i install them i know i have to drill out the 3 rivets but then how do i get them back together do i just go buy screws or do these come with screws? here is the kit i want
http://www.summitracing.com/parts/PTP-7-508/
Old Apr 12, 2010 | 08:34 AM
SweetZRag's Avatar
The kit comes with the instructions and the screws. It is very easy to follow. Autozone stocks these so you don't have to wait for the shipping.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
Feb 14, 2015 08:42 PM
1LEThumper
Jul 14, 2003 12:45 PM
