Does MAP sensor need grease?
Old Apr 11, 2010 | 11:16 PM
AdsoYo's Avatar
I'm replacing my MAP sensor and on the old sensor, around the base of the nipple and on the orange seal, it looks like it's had grease on it. Is this necessary, like for heat purposes or something? Or is it just 200,000 miles worth of build up?
Old Apr 11, 2010 | 11:43 PM
SnakeOiler's Avatar
most likely just oil residue buildup.
Old Apr 12, 2010 | 12:01 AM
monster81's Avatar
IMO a applying little grease on the seal will alow it to seat properly
Old Apr 12, 2010 | 02:03 PM
It may seal it a bit better. Just make sure you don't get any in the opening on the sensor, or hanging down into the intake manifold. Make sure its grease that won't deteriorate the rubber seal. Properly installed, a healthy rubber seal is usually adequate.
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
30th Anniv Z28
Aug 1, 2015 10:39 AM
Jlo
Jul 29, 2015 03:52 PM
Noct
Jul 14, 2015 01:18 AM
