New injectors for Hotcam?
Old Mar 27, 2005 | 01:16 PM
J96Z's Avatar
I am installing the LT4 HC in my car and having the heads rebuilt. I have everything apart right now and was just wondering if it would be a good idea to upgrade my fuel injectors while I'm in there. If so, what injectors and will I need an adjustable fuel pressure regulator?
Old Mar 27, 2005 | 04:13 PM
FastZinTennessee's Avatar
Re: New injectors for Hotcam?
I had some home ported heads with larger valves, a HOTcam, and the other supporting bolt ons. While scanning the car at WOT I saw the injector duty cycle go up to around 92%. I would have liked to see it lower. I guess what I'm saying is that the stock injectors will work, but if you have some money laying around some bigger injectors wouldn't be a bad investment. You wouldn't need an adjustable fuel pressure regulator, but I think you'd need some tuning to get your air/fuel ratio in check.
Old Mar 27, 2005 | 04:20 PM
94zgreenmachine's Avatar
Try to keep duty cycle to around 80%. The higher the cycle the more the injector is working, the higher chance for problems
Old Mar 27, 2005 | 04:38 PM
J96Z's Avatar
Can any of the various mail order tuners adjust the pcm for bigger injectors if I wanted to run the svo 30# injectors? I'll just go with those if I get new ones.
Old Mar 27, 2005 | 04:52 PM
Dave89IROC's Avatar
yes,they should all be able to
Old Mar 27, 2005 | 06:20 PM
svo injectors actually fllow almost 32#.Ford rates them at a lower pressure than GM pressures.
Old Mar 27, 2005 | 09:48 PM
J96Z's Avatar
So what injectors would be good for my application?
Old Mar 28, 2005 | 04:22 AM
The svo injectors should be fine.
Old Mar 28, 2005 | 04:27 AM
Are you just refreshing the heads? Doing any port work? Larger valves?
Old Mar 28, 2005 | 09:14 AM
J96Z's Avatar
I'm not having any port work done. Just a rebuild on the heads. I'm adding the hotcam kit, RKSport headers, 52mm TB, and a loud mouth exhaust. I'm also ditching the dual cat setup and running one high flow 3" cat.
G-BODYT56
Jan 14, 2022 11:14 PM
autoxr166
Sep 25, 2015 04:21 PM
MDZ28
11
Sep 24, 2015 09:15 AM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
