cam dowell pin?
Old Mar 27, 2005 | 08:47 PM
calfirebird's Avatar
cam dowell pin?
Im puting in an cam and the pin is too short. It is .500 when it needs to be .605-.620 i did a search and all i found was that of the pin being too long. How can i get the pin out some so it will work ok?
Thanks guys
Old Mar 27, 2005 | 09:09 PM
turbo_Z's Avatar
Re: cam dowell pin?
It will still work fine. Only when its too short to spin the opti are you gonna have problems.
Old Mar 27, 2005 | 09:57 PM
Red on Red WS6's Avatar
Re: cam dowell pin?
How short is to short? I think at .5" it is just barly in the opti.
Old Mar 27, 2005 | 10:11 PM
1quikZ's Avatar
Re: cam dowell pin?
test fit it and see if it will spin the dowell
Old Mar 28, 2005 | 08:59 AM
Re: cam dowell pin?
How can you tell if the dowell is spining once it is on? we put it on and it looks like it is in the slot but were not for sure.
Thanks guys
Old Mar 28, 2005 | 09:01 AM
Re: cam dowell pin?
Use some clay or play-doh to see how far it is engaged in the opti.
Old Mar 28, 2005 | 10:10 AM
Re: cam dowell pin?
So if it goes into the opti any amount it is fine?
If so that would be great i ll pick up some playdoe and check that out tonight. If we do have to pull it out, What is the best way to do that?
Thanks guys
rideordie
Nov 5, 2019 04:52 PM
sscott
Jan 17, 2015 04:30 PM
Queens94z28
Nov 20, 2014 06:03 PM
Red97LT1
Aug 15, 2002 08:33 AM
