new header bolts
Old Apr 17, 2006 | 09:48 PM
deputydough's Avatar
new header bolts
well it happened again. i had two bolts fall completely out. i tightend them every day for almost two weeks. then a month later they are gone. it is only the back ones. anyway, i went to autozone to get some more bolts. they had these kind that use a stainless wire that runs through one bolt to another. the concept isn't new, i know. but, i thought what the hey. has anyone tried these? i hope this solves my problem. i guess i will check them everyday or so from now on.
Old Apr 18, 2006 | 08:24 AM
Stoopalini's Avatar
Re: new header bolts
I have Stage 8 Locking Header Bolts on both my Z28 and my full size Blazer. I've never had one come loose. These things are great, and I would recommend them to anyone who doesn't want to be checking header bolts every month or so.
I bought mine from Summit, but some of the Supporting Vendors also carry them.
Thomas.
Old Apr 18, 2006 | 10:58 AM
89LT1Formula's Avatar
if you want and easier install then go with the Breslin's. They have a set screw in the middle that you tighten that expands them in the bolt hole and holds them just as good if not better than the Stage 8's.. and believe me... they are 10 times easier to install then the stage 8's.. you can find them on Summit as well.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
