new engine, what heads to go with?
Old Apr 18, 2007 | 07:55 PM
tagz's Avatar
Building a new engine for boost. I have a t76 turbo that i will be running. Capable of 900 hp. I'm shooting for around 700, 750.
The bottom end is gunna be fully forged. I want to get my compression ratio below 9.0:1. Even with -28 dish pistons, under 60cc combustion chambers put you at or a little above 9.0:1 compression.
I'm lookin for a set of heads that could handle the power, and with say a 64cc combustion chamber. What would you guys recommend? Should i just port out the stock lt1 heads, or should i be looking for a new CNC'd head? any recommendations?
Old Apr 18, 2007 | 08:04 PM
MeanGreen97Z's Avatar
You are going to want a set of heads built for larger chambers. The stock piece is going to be hard pressed to get into the larger CC numbers AND get the needed milling for flatness.
Old Apr 18, 2007 | 08:05 PM
SS1156's Avatar
AFR's to start and I would give Lloyd Elliott to do some port work.
Old Apr 18, 2007 | 08:15 PM
96capricemgr's Avatar
I would say look at Advanced Induction TrickFlows. My opinion of AFR is fairly low, more marketing than results.
Old Apr 18, 2007 | 09:00 PM
crushah's Avatar
I'm planning a twin-turbo set-up as well and I'm looking at going with RHS 235cc flowing 312/195. AFR do have some 215cc sbc competition heads flowing 325/230...they running about 3400.00.
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
