new engine acting up
Old May 24, 2005 | 06:49 PM
spcearle's Avatar
ok to start with the prob...my car runs fine and all until i hit wot and at about 5500 and up the the car is stumblin alot till it shifts and then run fine again.....as for the car it has a new 383 stroker in it with lt's/58mm tb/30lb.inj/stock maf/and custom tuned comp...prior to this prob the opti was changed because it again was running great but then hit about 5800 and died completely and wouldnt get a good spark or crank right so we changed the opti and all was good...also no codes/good new nkg 55 titaniums.good coil and icm....i'm thinkin the pump is starvin and i need a bigger one but not sure yet any help would be great here
Old May 24, 2005 | 07:08 PM
1racerdude's Avatar
Re: new engine acting up
What valve springs? Sounds like valve float or bounce.
Check fuel pressure and see if it's the pump.
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
DetroitZ28
Feb 13, 2015 07:33 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
97z28k&N
Jan 9, 2015 04:58 AM
