New Coil.. Which One
Old Feb 18, 2007 | 03:13 PM
  #16
Critter's Avatar
it will only help it burn better if it is not a complete burn in the first place, you would have to establish that the stocker is not sufficient. i think it could be better spent elsewhere. but i've been wrong before. only three times though, not bad for being 24 i guess.
Old Feb 18, 2007 | 03:29 PM
  #17
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I'm speculating that my car had been running rich because it went through a couple of cats. I'm not sure of everything that would cause a rich condition, but I've installed a new MAF and new O2 sensors. I was just curious if it continued to run rich whether a hotter spark would be of any benefit.
Old Feb 18, 2007 | 03:39 PM
  #18
Critter's Avatar
it would help, also what is your plug gap?
Old Feb 18, 2007 | 03:46 PM
  #19
BTC's Avatar
BTC
I honestly have no idea, but the gap is probably whatever is called for. The plugs in it are the AC Delco Platinum plugs that would have been installed by a dealer. I'll be putting in new plugs and wires at some point, but I'm thinking I may wait until I put on some headers before changing all of that out as headers could require new wires and I don't really want to buy them twice.
Old Feb 18, 2007 | 04:39 PM
  #20
2000GTP's Avatar
If its running excessively rich, there is a problem somewhere. Do you have any exhaust or vacuum leaks? How long ago were the plugs and wires done? The AC Delco platinum plugs are notorious for dropping their pucks resulting in a plug gap of almost double.
Old Feb 18, 2007 | 09:07 PM
  #21
BTC's Avatar
BTC
I'm honestly not sure about the exhaust or vacuum leaks. I did pull a couple of the plugs and they still had the puck on them. They appeared to be in decent shape, but there was some soot which I think indicates a rich mixture.
Jlo
Mar 6, 2013 01:59 PM
formula90
Nov 9, 2011 09:57 PM
Cabikejumper
May 8, 2011 09:37 PM
93_ZZZZ
Apr 15, 2010 07:24 AM
96camaroNM
Dec 5, 2009 03:08 PM
