New Coil.. Which One
Old Feb 17, 2007 | 01:50 PM
Sdimein's Avatar
Need a new coil for the car.. any recommeneded brands.. if so, best place to order ?
Old Feb 17, 2007 | 01:58 PM
2000GTP's Avatar
There is nothing wrong with just using another factory Delco coil. Otherwise, you could always opt for an MSD replacement. Check out the supporting vendors if you want an MSD coil. Otherwise, one of these gentlemen can get you a decent rate for a Delco: http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Feb 17, 2007 | 05:08 PM
You can't get good advice without some car info.
Old Feb 17, 2007 | 09:14 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Is the stock coil wire and ICM sufficient with the MSD 8226 coil?
Old Feb 17, 2007 | 10:00 PM
Critter's Avatar
stock coil on any lt1 unless your into the extreme hp ranges
Old Feb 17, 2007 | 10:07 PM
Makaveli's Avatar
i remember hearing years ago about guys complaining about opti problems after installing an MSD coil. is there anything wrong using an MSD coil?
Old Feb 17, 2007 | 10:47 PM
Critter's Avatar
its overkill i've read the same, your not going to gain anything with a better coil than oem so why waste the money or potentially burn up an opti or icm
Old Feb 17, 2007 | 11:50 PM
No, there is notthing wrong with it. 93-95 stock coils are a little weaker than 96-97 coils. Therefore, you could potentially benefit by upgrading the earlier coils. It won't harm your opti, either.
Old Feb 18, 2007 | 12:23 AM
Critter's Avatar
what about the icm? i don't remember the formula for multiplying the output of the icm and coil but with the msd i remember it being super high.
Old Feb 18, 2007 | 08:10 AM
I can tell you that I have not had any problem using a Blaster coil and stock ICM for almost 8 years. I don't think that indicates any kind of incompatibility or harm being done. With the resistance at the coil terminals being lower than stock coils, I would think the ICM would have an easier time switching the coil on and off.
Old Feb 18, 2007 | 10:06 AM
BTC's Avatar
BTC
Considering that I have committed to purchasing an MSD coil, I like shoebox's answers the best.
Does it make any sense to change out the ICM & Coil at the same time? I'm going to be putting in a new distributor and I'm looking to do some preventive maintenance. Is there anything preventive about putting in a new ICM, or coil for that matter? Do those parts wear out? Also, do the service manuals use the terms Ignition Control Module & Ignition Coil Module interchangeably?
Old Feb 18, 2007 | 10:10 AM
TKH_Z28's Avatar
I had a MSD blaster coil on mine with the factory opti it wasn't worth having. After i put the MSD distribitor in i put that coil back on and it was fine.....If your going to do it do it right and up the entire firing system.
Old Feb 18, 2007 | 10:54 AM
2000GTP's Avatar
The ICM module isn't something that has a "required replacement" interval.
Old Feb 18, 2007 | 12:40 PM
Critter's Avatar
well then we can come to the conclusion that it won't fry opti's or icm's. but do not expect a gain in hp?
it this is true i don't see what the point is?
Old Feb 18, 2007 | 03:09 PM
BTC's Avatar
BTC
It won't give you 30 hp?
Would a hotter spark have any effect on a rich fuel mixture? Would it burn better?
