New coil; which one?
Old May 17, 2003 | 08:13 AM
  #16
rskrause's Avatar
Moderator
The original stock coil seemed to work fine on my 733rwhp setup last year. I replaced it with the one from Accel 'cause I like the color of the Accel, not because it was malfunctioning or because I think it will work any better.
Rich Krause
Old May 17, 2003 | 10:07 AM
  #17
Thomash's Avatar
I have to admit i never saw a coil as an appearance item.:-)
I'm using a MSD. I did have to drill out the rivets for the stock coil. No big deal. I painted the body of the coil black so it looks stock.
Old May 17, 2003 | 10:20 AM
  #18
Dave Feerst's Avatar
I would think more ohms would mean more coils. But then again they usually add coils to the priamry side since it has much more effect on a coils outpot.
Old May 17, 2003 | 04:05 PM
  #19
PROJEKT Z28's Avatar
Originally posted by shoebox
Hmm... if ACDelco makes the MSD coil, they don't make them the same as the stock ones. My MSD has ~2800 ohms less resistance than the stock coil. Who is to say a stock coil is adequate to begin with?
What is the resistance of the stock coil?
Old May 17, 2003 | 04:07 PM
  #20
Hawk's Avatar
Originally posted by GEES97TA
Were can i get a ACCEL or MSD for a 97 lt1,and will it help me if im running a accel 300 plus ignition box ,plus i do have a supercharger if that matters?
96/97 cars have good coils already,thats why they don't include them in the ignition kits. Mine's stock, thats all u need.
Old May 17, 2003 | 05:26 PM
  #21
Mine was ~ 8100 ohms.
Old May 17, 2003 | 09:54 PM
  #22
rskrause's Avatar
Moderator
What I meant was that since they would all work the same (IMHO) why not pick one that would add a little color to my drab engine compartment! That yellow is kind of eye catching. MSD red isn't bad either. BTW: these coils look suspiciously alike.
Rich Krause
Old May 19, 2003 | 02:37 PM
  #23
hairbear21's Avatar
The primary side of the coil will have less resistance that the secondary side of the coil. The primary side of the coil is where the "input" voltage is applied from the ignition. The secondary side of the coil is where the output voltage is. That side will have more windings, and it will offer more resistance. Either way though, the resistance should not be that high, maybe only in the thousands. If you get into the tens of thousands, then you have a problem.
Old May 19, 2003 | 03:34 PM
  #24
LT1derful's Avatar
New question for this.
Bought a coil, stocker is rivoted or whatever to the bracket that bolts to car. How do I remove the stocker so that I can replace it? What tools etc. I just don't want to screw up the bracket and have to buy that too!
Old May 19, 2003 | 03:42 PM
  #25
hairbear21's Avatar
You can drill the rivets out, or you can take a chisel to one end, and tap it through. I did the latter, and it worked fine.
Old May 20, 2003 | 01:11 AM
  #26
Fatdog's Avatar
Cool
If the car runs good,why spend this money(and time)on this?.Buy beer.Happy motoring.My02
Old May 20, 2003 | 08:17 AM
  #27
LT1derful's Avatar
Well, car has a slight stumbly feel to it. Changed all plugs and wires and opti seems to perform OK (has about 30K miles on it). The coil has over 160K miles on it; and I've already spent the money.
And beer...hey, who works on their car without drinking beer anyway?!
Old May 20, 2003 | 09:32 AM
  #28
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
LOL, i know i always gotta knock a couple down when i get frustrated working on my car. About getting the coil off i did the same as hairbear21 did, worked fine.
Chris
Oh and i went with the AC Delco. Works fine.
Old May 20, 2003 | 10:55 AM
  #29
GEES97TA's Avatar
Thanks HAWK, just was wondering because when they dynoed tuned my car they said they thought there was something wrong with the accel ignition box now im on the stock ign,and they said im blowing out the spark on uppper RPM's so i wanted anything that might help how about a module or can the coil be going bad?
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Z Power
Sep 19, 2015 11:19 PM
