new alternator still low voltage
Old Mar 1, 2004 | 09:46 PM
NewbieWar's Avatar
is there some kinda voltage regulator?
my fan belt is sqeeling could it be its getting no traction at all?
(belt is new just got antifreeze spraying it)
Old Mar 1, 2004 | 09:53 PM
OBE1 95Z28's Avatar
The regulator is built into the alternator. Did you remember to reconnect the sense line (connector on the back bottom of the alternator)? Also check that you have good connections (not loose or dirty) at the end of all your battery/alternator harnesses.
Old Mar 1, 2004 | 10:06 PM
NewbieWar's Avatar
all good connections... i'll look again when it isnt raining tho
but gauge chilling at 11 volts while running sometimes up to 12 or 12.5
Old Mar 1, 2004 | 10:11 PM
OBE1 95Z28's Avatar
Your wet belt may be slipping. You can buy a can of belt dressing to see if the problem goes away. It's only a temporary solution but will allow you to diagnose your problem.
Old Mar 1, 2004 | 10:22 PM
BC94Formula's Avatar
i have a similar problem sometimes...could a underdrive crank pully cause any of that...i didnt think it could but someone told me otherwise (someone always tells you something they know nothing about)...but at this point im willing to look anywhere...also every once and a while there is a really bad idle problem...it will go down to like 3-400 rpms and stay there...volts drop almost all the way off until i give it a rev and it goes back up real fast..if i dont it will usually die but sometimes will hold idle if i have my stereo a/c etc off...but it causes some really scary driving as when i have the clutch in and take turns the power steering tries to go out as a result of the low rpm's...could this be the tensioner?
Old Mar 1, 2004 | 10:34 PM
NewbieWar's Avatar
but it doesnt budge from that 11.5 mark
its making the check gauges light flicker on and off
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Lt1son
May 27, 2015 10:35 AM
Gtpguy
Jan 26, 2015 04:50 PM
