need a wiring diagram
Old Jun 16, 2004 | 12:21 PM
chy20k1's Avatar
i need a wiring diagram for the rear lights on a 93 firebird formula. they werent working right, so i go and take the lights out to check em out and it looks like someone was in there messing with the wiring at one point. thanks
Old Jun 17, 2004 | 05:32 AM
slopokrodrigez's Avatar
I can only tell you some of the wiring as I don't have a way to get the diagram to you. The 2 element bulbs will give you fits but the singles will be easy. The left hand tail lamp (single element) and the left marker light have brown wires as do the two on the right side. The two with dual elements (outboard and inboard) have a brown wire and one other wire. The left side dual element bulbs have a yellow wire going to them and the right side dual element bulbs have a dark green wire going to them. Naturally they all have a black ground wires going to them as well.
Left side
Brown (single element bulb)
Brown and Yellow (dual element bulb) total 2 inboard and outboard
Right side
Brown and Green (dual element bulb) total 2 inboard and outboard
Old Jun 17, 2004 | 08:55 AM
chy20k1's Avatar
thanks for the help.
Old Jun 17, 2004 | 09:04 AM
SWINGRRR's Avatar
Ill send you the one I have for a 95 Formula. Im not sure of the differences though, if any, in the years. If there is a difference, jump onto www.speeddensity.org and hit up Fastbird93, or Knightfire. Im sure either one of them would have it.
Apr 27, 2015 06:08 AM
surreybrad
Apr 22, 2015 06:40 AM
titanthomas
Apr 18, 2015 11:44 PM
EdgarArmada
Apr 18, 2015 05:20 PM
blac94Z
Mar 20, 2015 09:58 PM
