need valvetrain help fast someone please help!!
Old Jul 31, 2004 | 12:49 AM
1badasZ's Avatar
i got my LE heads in today. i didnt have a flow number sheet in there but maybe it slipped his mind with all thats going on. either way the heads look good. i need help with valve train stuff. k i have crane 1.6SA RR's and a cc305 cam. im sending the cam back to get something bigger like maybe the 230/236 or something. i have some crane lifters. can i use the xe cams with the SA RR's and the crane lifters? i cant afford to buy a whole new valvetrain right now...comp r lifters, nonSA rr's, guide plates n stuff. so am i stuck with the cc305?
Old Jul 31, 2004 | 12:50 AM
1badasZ's Avatar
Re: need valvetrain help fast someone please help!!
and also if im able to run the 230/236 will i be able to use my vigilante 2800 for a month or so until i can send it back to be turned up?
Old Jul 31, 2004 | 06:43 AM
1badasZ's Avatar
ttt
Old Jul 31, 2004 | 08:20 AM
rskrause's Avatar
Moderator
I don't see why you can't use the parts you have. Be sure to measure to get the correct pushrod length as with the new heads and a different cam you may need a different length.
Rich
Old Jul 31, 2004 | 06:37 PM
1badasZ's Avatar
Rich
yea they have been milled and i have impala head gaskets and thinking about going with the 230/236 so do you think i will need the shorter ones?
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
