Need Trouble Code Help
Old Jul 10, 2007 | 01:35 PM
bg552's Avatar
Scanned my 95 LT1 m6 today and it threw the following codes:
27: EGR electrical fault
32: EGR failure
26: Canister Purge electrical fault (would this explain gas smell?)
77: Fan 1 fault (fuses look good, whats next?)
84: Third to second gear downshift feedback fault
83: Torque converter/clutch control feedback fault
I imagine EGR failure is just linked to the electrical fault. Any help with any of these codes would be much appreciated. Just bought the car yesterday and am workin out the bugs. Thanks in advance.
Old Jul 10, 2007 | 06:09 PM
The fan relays, EGR solenoid and EVAP solenoid are all on the same fuse - #6 in the underhood box.
Since you have an M6, you are using the wrong codes table - your tranny doesn't have a "Third to second gear downshift feedback fault" or a "Torque converter/clutch control feedback fault". Those are for an A4. With an M6:
DTC 83 = Reverse inhibit system (manual transmission)
DTC 84 = Skip shift solenoid circuit (manual transmission)
Both those solenoids run off fuse #6 in the underhood box .
Are we beginning to see a pattern here?
And, are these active codes, or stored codes? Did you try clearing them by pulling the "PCM BAT" fuse for 30 seconds, to see if they come back? If the reverse lockout solenoid was inactive, it would be extremely difficult to force the shifter into the far right slot for "reverse".
Old Jul 10, 2007 | 08:59 PM
bg552's Avatar
Checked the fuse and it was still good. Might just be old codes, i cleared them with the scanner so we'll see if they come back. Thanks
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
