need tranny removal help
Old Jun 24, 2004 | 07:13 AM
clownhair's Avatar
taking out my m6. I have everything ready to drop but I can only get the tranny to back out about an inch and then it seems to be hanging up on the throw out bearing arm. Anyone have any help??
Old Jun 24, 2004 | 07:26 AM
izzyz28's Avatar
I ran into this problem too and fought it for an hour before I figured it out. On the Lt-1 clutch assembly the throwout bearing pulls rather than pushes on the diaphram spring. This means that the bearing is on the BACKSIDE of the pressure plate, so it will not come out with the tranny. SOOOOO, you need to take a prybar and try to slide the clutch fork off of the throwout bearing. It may take a couple of tries, but you'll get it. Try to slide it straight off using the slave cylinder hole for access. Heck, a screwdriver or hose pick might work also. Best of luck, and if you have any more questions feel free to post.
Izzy
Old Jun 24, 2004 | 08:41 AM
Red96Lt1's Avatar
He is corrrect except he left out a very important detail. T-56's use a reverse clutch like he said. So instead of a ball that the clutch fork pivits on, there is a bolt that it pushes against. Remove this screw so that you can get the clutch fork out.
Old Jun 24, 2004 | 09:16 AM
izzyz28's Avatar
There must have been something broken inside my bellhousing then, because I didn't unscrew anything. I don't even know how you could get a wrench in there to unscrew it. When I slid my clutch fork back it positively clicked when it disengaged, and it snapped into place when it engaged with the new clutch. It's been fine for 10,000 miles. I am in no way implying that you're wrong, but I am wondering what the GM service manual says about this. Anyone want to chime in and help clear this up for me? Now I'm confused.
Old Jun 24, 2004 | 03:29 PM
Ditto... no need to remove the T-bolt that the clutch pivots on. Just pull the fork straight to the side, and the spring that holds the fork on the T-bolt will allow the fork to pop loose.
Old Jun 24, 2004 | 03:36 PM
izzyz28's Avatar
Thanks for clearing that up Injuneer.
Old Jun 24, 2004 | 06:38 PM
clownhair's Avatar
what way do I pry on this thing to get it to come off? I am still having problems.
Old Jun 24, 2004 | 09:38 PM
clownhair's Avatar
Old Jun 25, 2004 | 12:44 PM
You move it in a straight line, directly away from the input shaft. If you are behind the bellhousing, looking into the hole for the slave cylinder, it pulls to the left. The only thing holding the fork on the T-bolt is two small (but strong) spring fingers.
http://cjcfo.fbody.com/members/injun...C/DCP02754.jpg
Old Jun 25, 2004 | 11:33 PM
clownhair's Avatar
thanks for your help Injuneer. I was able to get that but now I am having problems with the bellhousing hitting the firewall and the tranny will not budge.
Old Jun 25, 2004 | 11:51 PM
Dave89IROC's Avatar
did you unbolt the trans from the bellhousing?
Old Jun 26, 2004 | 12:17 AM
clownhair's Avatar
No.....?
Old Jun 26, 2004 | 09:45 AM
Dave89IROC's Avatar
do they still come apart?
i thought they did?
dylan1303
Aug 12, 2015 02:00 AM
BigWil
Mar 29, 2015 12:24 PM
mattszm6
Dec 14, 2014 07:09 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
