Need timing chain info!!!!
Old Aug 15, 2003 | 08:54 PM
z28boysteve's Avatar
Angry Need timing chain info!!!!
Does the LT4 Extreme duty timing chain set work on a 94 Opti with splined shaft drive?
where can I find, JUST the LT1 timing chain, and the chain only, and how much is the thing, and what is the part number
Old Aug 15, 2003 | 09:19 PM
can someone please answer this?
Old Aug 15, 2003 | 09:37 PM
speedmiser's Avatar
No. Wont work with the non-vented opti. You can get the stock chain at one of the many GM dealerships in Houston. Go to the parts dept. Or Racenet or one of the other speedshops in town should be able to get you the stock chain.
Old Aug 15, 2003 | 09:53 PM
car_ramrod's Avatar
If I was you
If I was you id get an electric waterpump and a real timing chain like a cloyes double roller or equivalent, and those together can be had for about as much money as the weaker LT4 ED unit. Im not sure if you'd have to upgrade to the vented opti at the same time or not, cuz i have a 95, but thats what id do. hope this helps.
CR
Old Aug 15, 2003 | 09:57 PM
speedmiser's Avatar
Actually, I have a brand new stock chain P/N 10128485 - unopened - still in the GM shrink wrap. I beleive they are about $30 - dont quote me - I forgot exactly what I paid for it. I'll sell it to you for $15 though, if you pick it up. I'll be out of town this weekend, but I'll be available during the weekdays next week. PM me if interested.
I decided to do the vented opti converstion, with elec water pump, and double roller, that's why I never used the stock chain. If you want to use the ED, Lt4, or Double roller, then yep, you've definitely got to do the vented opti converstion. I just went through this myself on my 93.
Old Aug 15, 2003 | 09:58 PM
funina91ss's Avatar
He would have to get the 95 vented opti and the 95 timing cover.
Old Aug 15, 2003 | 10:09 PM
speedmiser's Avatar
Well, if you're doing the coversion, you can also use the 96 or 97 cover if you can find one available - you just have to leave the Crank position sensor plug on, or cap the hole with a freeze plug.
Old Aug 15, 2003 | 10:11 PM
thanks for the offer, but Id rather go to the parts store just becuase its convenient, unless you live close to seabrook, or clear lake, one more question, will a 95+ chain (not the gears) be the same as a 92-94?
Old Aug 15, 2003 | 10:55 PM
Stock 93-97 chains are the same.
Old Aug 15, 2003 | 11:02 PM
thanks a ton, that sure is a breathe saver, I was worried as hell I wouldnt be able to get a new chain, do you think the gears on a motor with 114,000 miles are worn out too?
Old Aug 15, 2003 | 11:13 PM
I don't even have to think. Yes, they are. Get a chain and both gears.
Old Aug 16, 2003 | 10:14 AM
F-body Scotty's Avatar
DO NOT BUY AN LT4 TIMING SET FOR A PRE 95 LT1!!!!
it will not fit the little cam driven shaft, and wont fit with the cover either,......
Old Aug 16, 2003 | 12:13 PM
12SCNDZ's Avatar
I put a new factory chain back on mine. I did a search a while back, and found that all the changing/swapping isn't really worth the hassle. An Lt1 hardly ever has a timing chain failure...Unless...It's extremely high milage. A "good" chain will also fail under high milage conditions.
Frank
Old Aug 17, 2003 | 09:04 PM
speedmiser's Avatar
Nope, I'm all the way across town, on the westside.
As shoebox, mentioned - Definitely replace the gears too, if they've got 100k+ on them...
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
