need some part numbers
Old Sep 15, 2004 | 09:28 AM
MonkeyManZ28's Avatar
i need the part number for tb plate gasket the rubber one, the oil level sensor or temp sensor (the one that is directly above the drain plug on the oil pan, and the part number for the maf, also can i say use a maf from a truck or any other car that uses the same type of maf, from what i understood was that all mafs in the trucks, silverados, s-1os are the same. does anyone know?
Old Sep 15, 2004 | 09:29 AM
944v8inDFW's Avatar
Re: need some part numbers
part number list: http://shbox.com/1/Parts.htm
Old Sep 15, 2004 | 06:44 PM
Stick with an f-body MAF. Others may not be compatible to the calibrations in your PCM.
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
