need some lt1 help
Old Jun 10, 2014 | 07:27 AM
  #16
LT1_383_Stroker's Avatar
Re: need some lt1 help
Just a crazy question: aren't the MAFs between an Impala and Camaro different sizes? Will they register the same amount of airflow? I thought the Impala folks like to install F-body MAFs because they were bigger. I'm not sure if anything in the ECM needed to be changed. I could be wrong. Injuneer probably knows!
Old Jun 11, 2014 | 05:09 AM
  #17
jcroff's Avatar
Yes both vehicles are 94's....the 383 was in my impala and ran fine I swapped heads and put it into my Camaro. It has 42lb green tops in it, tuned by pcm4less. I'm going to check over the rocker arms I'm thinking they may be adjusted on the tight side. Other than that I'm out of ideas.
Old Jun 11, 2014 | 06:58 AM
  #18
Cam's maro's Avatar
So, the heads that are on your stroker 383, that is in your camaro now and not running, are the factory camaro heads? Non ported with the ported 383 intake?
Old Jun 11, 2014 | 09:57 AM
  #19
Dtimekw's Avatar
Why the head swap? Like Cam's Maro said, are they stockers? That WILL change everything due to a different comp ratio, flow etc...
Old Jun 12, 2014 | 10:27 AM
  #20
jcroff's Avatar
They're ported stock heads just like the ones I took off just ported better
Old Jun 12, 2014 | 02:22 PM
  #21
Dtimekw's Avatar
Its hard to say. Ported better how? If there is a drastic difference in the two sets of heads, that could be part of the problem. Were you able to scan for any codes?
Old Jun 23, 2014 | 07:09 PM
  #22
jcroff's Avatar
finally fixed ended up being the tiniest crack in the fuel pump hose leaking into the tank. just goes to show how checking the basics usually fixes the problem...................now who has a tune i can bum for my camaro pcm so i can drive this thing. just need a base to tinker with and see how she runs pm me if anyone can help out thanks for all the responses
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
