need some info on intake manifold
Old Apr 1, 2011 | 05:53 PM
DTRJAR's Avatar
Exclamation need some info on intake manifold
ok so i want to buy the edelbrock intake manifold summit # edl-7107 need to know if it is worth the money and will i get any power out of it thanks
Old Apr 1, 2011 | 07:07 PM
Re: need some info on intake manifold
Absolutely not. It's no better than the stock one. With your mods, you don't need to be thinking about an intake.
Old Apr 1, 2011 | 08:48 PM
RamAir95TA's Avatar
Rob's right on. It's the biggest piece of crap, and has actually shown in some cases to REDUCE HP.
Old Apr 2, 2011 | 01:44 AM
doferrell's Avatar
all u have to do is port your intake and powder coat it and u have the exact same thing.
Old Apr 2, 2011 | 08:33 AM
my1994z28's Avatar
Dont mean to jump in but,What if you fully port the Edelbrock intake?
Old Apr 2, 2011 | 08:47 AM
There's not much to "port" on either the stocker or the Edelbrock. The runners are only 3+" long. Other then providing a smooth transition to ported head runners, there's not much you can do to either. The problem with the Edelbrock is reduced plenum volume. The higher your air demand, the bigger the problem becomes. They gave up plenum volume to provide the "air gap" design, and it wasn't a very smart trade off.
Old Apr 2, 2011 | 10:51 AM
DTRJAR's Avatar
Thanks guys u saved me 500$
Old Apr 2, 2011 | 12:35 PM
96capricemgr's Avatar
Depends you bench racing or talking about the real world?
I am sure the bench racers will tell you it is awesome but wont be able to back it up with any result.
Stock shortblock NA cars are topping 400rwhp with intakes just ported for a larger TB, no internal work. The LT1 intake works so well Lingenfelter and Edelbrock both failed to make any meaningful improvement in the 90s and they both tried. When the LT4 intake went out of production Edelbrock let some of their integrity go and released a marginal product be cause they knew all they needed was their name to sell it and the result didn't actually matter.
Old Apr 2, 2011 | 04:31 PM
my1994z28's Avatar
Damn,I have the Edelbrock intake and had it fully ported before I installed it on my motor.....Think its worth 350.00 shipped???
Old Apr 2, 2011 | 06:03 PM
RamAir95TA's Avatar
IMO it's worth no more than a used stock ported manifold.
Old Apr 2, 2011 | 09:20 PM
They look nice, little more showy, that is worth something to some folks. Those who have seen my car know I am not one of those folks.
Old Apr 6, 2011 | 10:49 AM
STOCKTA's Avatar
I would not jump on the ported intake not making gains bandwagon!
This is a LE ported intake swapped to a epoxy/ported intake with fixed runner geometry and plenum work.
Picked up 1.8mph and .14et in worse conditions on a very dialed in LT1 car with an honest person doing the data logging with every 1/4 pass. Take it with a grain of salt but the gains are there if you do the work on it.
http://www.ls1tech.com/forums/lt1-lt...e-results.html
This is not much more work over the traditional ported intakes just more attention to detail and plenum volume, the epoxy is to allow more aggressive runner raising without punching through casting. Do a search on Jordan Musser and you will see his idea behind the welded runners.
I agree on the edelbrock being junk out of the box but it sure looks good and has much thicker runners for tons of port work
Josh
Old Apr 6, 2011 | 10:53 AM
RamAir95TA's Avatar
While I agree with the above to an extent, that testing was done on a far more aggressive setup than what the OP is looking at (stock bottom end, stock heads, CC304 cam).
There's no doubt that on a more aggressive setup that porting the stock manifold can yield gains, albeit small.
Old Apr 6, 2011 | 11:24 AM
STOCKTA's Avatar
I admit I did not look at his sig or specs so to OP, stick with a stock intake other than the need for a 58MM cut if running new TB.
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
