Need some help please! i cant get this thing running
Old Apr 19, 2006 | 05:36 PM
yzblue125's Avatar
some quick back ground, the car died on me just normal driving, i replaced the opti becaude it was bad. now the car runs and idles great for about 45 sec then just dies and wont start back up unless you let it sit for a few hours. i ran the code scanner on it and picked up some weird factory power drivetrain code? any ideas
Old Apr 19, 2006 | 06:40 PM
Stoopalini's Avatar
Re: Need some help please! i cant get this thing running
What's your fuel pressure at?
If you don't know, go get a fuel pressure gauge and check it. There's a port on the fuel rail to do this. Plug the gauge in, turn key on and check gauge. Then start it up and watch the gauge to see if the pressure starts dropping unit the motor cuts off.
Thomas.
Old Apr 20, 2006 | 12:06 AM
yzblue125's Avatar
ok i took my car over to my buddy mikeys house and i think i found the problem, we ran his bad *** scanner on my car and kept getting a low voltage signal,so after checking a few things we found that if i wiggle the main plug into the opti the car will start but will still die,wiggle it and it will start right back up and die again. got a new plug for it still same problem, is there any way the optis plug could be jacked up? its brand new. remanufactured one from advanced.
Old Apr 20, 2006 | 12:54 AM
blitzer454's Avatar
FWIW I went through two optispark modules that I brought from Autozone within just a couple of weeks after installing them. The third time I put in an original GM replacement and haven't had a problem since. On one of the bad ones, the engine died unexpectedly but I was able to restart it and get it home. The other one just died and I had to have it towed home. Moral of the story, get an original optispark.
DirtyDaveW
Dec 1, 2016 05:37 PM
Amshnock
14
Jan 18, 2015 11:47 AM
nophix
Nov 30, 2014 10:26 PM
Hal Fisher
Sep 14, 2002 09:36 PM
