Need some help with decideing what to do with the opit prob.
Old Dec 31, 2004 | 06:19 PM
fesgali's Avatar
My wp went out and the last time i moved it into the garage coolant leaked onto it and starting it after it was a little hot it gave me a hard start and also gave a SES light. I'm thinking about goin ahead and changing the opti so i don't have to take everything off again to change it out if it's actually shorted out.
Heres the options:
1) Change the entire optispark unit ($250 from gmpartsdirect)
2) Change the cap/rotor only with the MSD cap/rotor and hope the optisensor is still good ($150 thunderracing)
3) Cross my fingers and leave it on and hope it's not messed up (suprisingly $0)
Other ignition options (delteq, ltcc, etc) are not available due to student budget.
Old Dec 31, 2004 | 06:48 PM
Re: Need some help with decideing what to do with the opit prob.
Another option: get new opti from Dal or Jason and pay closer to $210 for it.
Old Dec 31, 2004 | 07:02 PM
fesgali's Avatar
Thats a thought...what would u do?
Old Dec 31, 2004 | 10:40 PM
I would first check to see what the code was.
Old Jan 1, 2005 | 08:04 PM
fesgali's Avatar
I got the wp off and the radiator fans off. Is it ok to put the car into the "on" but not crank it to see what the code was?
Old Jan 1, 2005 | 08:53 PM
Robs97Z28's Avatar
Yeah, you will have other codes will be set because of the things that right unplugged. Just reset the ECM after you get everything back together.
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Bxlt1
Sep 29, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
