need some help
Old Jun 13, 2007 | 01:06 AM
pony_killer95's Avatar
need some help
ok my camaro wont run...
its a 93 z28 lt1....
fuel is making it all the way to the fuel rails...
put new fuel filter and pump is working great....
it seems that the engine is not getting gas...
it fires up with starter fuel but then dies...
fuel injectors? electrical...?
need some help thanks
Old Jun 13, 2007 | 08:38 AM
2000GTP's Avatar
I would put a gauge on the Schrader valve and see what the fuel pressure is doing.
Old Jun 13, 2007 | 09:54 AM
n2ceptor's Avatar
Could be a number of things.... fuel pressure, no signal to fuel injectors, loose connection, etc..
Are there any codes???????
Old Jun 13, 2007 | 09:57 AM
ZL1modified's Avatar
i would guess a weak spark... starting fluid is highly combustable and does not need much heat to combust...
i would pull a plug and see if it looks wet...
Old Jun 13, 2007 | 12:28 PM
what is a good pressure reading.... at least what??
If the fuel pressure is good... what is a way to test the connection... i pulled out the fuses for the injectors and both 7.5 amps were good...
when you say pull and plug do you mean pull a spark plug wire from the block and feel for any liquid?
i dont have a comp reader.... where is a good place to pic one up and price?
Old Jun 13, 2007 | 12:35 PM
no, i meant pull a spark plug and see if it is wet... this would tell you if you are getting fuel and no spark... i honestly don't think it is a fuel problem...(but i have been wrong befor)... good luck
pressure should be ~38 psi @ idle...
Old Jun 13, 2007 | 12:38 PM
ok so pull a spark plug and if it is wet that means im getting fuel and no spark...
if that is the case should i be thinking opti or anything else
Old Jun 13, 2007 | 01:12 PM
could be bad plugs (cheapest), wires, ignition coil, or Opti(Most Expensive)...
always start with the cheapest...
Old Jun 13, 2007 | 05:35 PM
ok checked the plugs and they are wet...
i figure im going to have to replace the opti because the wires are about 15000 old and the plugs are about 5,000 old....
unless it could be something electrical that the comp would tell me...
so if i have to go for a new opti... whats the best place to get one and is there any good manuals online with picture of how to fix one step by step..?
Old Jun 13, 2007 | 05:48 PM
i would recommend oem gm style... i been thru the whole accel thing...(not impressed)
i would check the coil befor you just go and buy a 300 $ part...
Old Jun 13, 2007 | 05:50 PM
Try checking the ECM for codes. You don't need a scanner on a 93.
http://shbox.com/1/dlc2.jpg
Old Jun 13, 2007 | 05:57 PM
ok first how do i check the coil???
next i did not understand that link for the shoebox and how to check it? where is this exactly?
Old Jun 13, 2007 | 06:02 PM
Shoebox's (he's a person - probably one of the most knowledgable on this site) link tells you how to get the codes from your computer.
It tells you how to "flash" the ECM trouble codes on the SES light, by shorting the ALDL pins. Look at the column on the right labeled "Flashing DTC's".
