need some help
need some help
ok my camaro wont run...
its a 93 z28 lt1....
fuel is making it all the way to the fuel rails...
put new fuel filter and pump is working great....
it seems that the engine is not getting gas...
it fires up with starter fuel but then dies...
fuel injectors? electrical...?
need some help thanks
what is a good pressure reading.... at least what??
If the fuel pressure is good... what is a way to test the connection... i pulled out the fuses for the injectors and both 7.5 amps were good...
when you say pull and plug do you mean pull a spark plug wire from the block and feel for any liquid?
i dont have a comp reader.... where is a good place to pic one up and price?
no, i meant pull a spark plug and see if it is wet... this would tell you if you are getting fuel and no spark... i honestly don't think it is a fuel problem...(but i have been wrong befor)... good luck
pressure should be ~38 psi @ idle...
ok checked the plugs and they are wet...
i figure im going to have to replace the opti because the wires are about 15000 old and the plugs are about 5,000 old....
unless it could be something electrical that the comp would tell me...
so if i have to go for a new opti... whats the best place to get one and is there any good manuals online with picture of how to fix one step by step..?
Shoebox's (he's a person - probably one of the most knowledgable on this site) link tells you how to get the codes from your computer.
It tells you how to "flash" the ECM trouble codes on the SES light, by shorting the ALDL pins. Look at the column on the right labeled "Flashing DTC's".
