need some help on a 383 build
Old Jan 2, 2008 | 02:42 PM
  #16
96 mikez28's Avatar
Originally Posted by rskrause
If you can't spring for the "regular" Callies line, which is made entirely in the US,
good to know, prolly what i'll be looking at getting
Old Jan 2, 2008 | 03:07 PM
  #17
Eric@Victory Racing's Avatar
VRE383F-1- Victory Racing Engines Forged 383 Speed Pack, 3.750" Callies Dragonslayer Forged crankshaft, Diamond flat top pistons, Diamond Pro-Select rings, Clevite Bearings, Compstar 6.000" connecting rods, 1pc seal $2349.99
VRE383I-1- Victory Racing Engines Forged 383 Speed Pack, 3.750" Callies Dragonslayer Forged crankshaft, Diamond dish pistons, Diamond Pro-Select rings, Clevite Bearings, Compstar 6.000" connecting rods, 1pc seal $2399.99
VRE383D-1- Victory Racing Engines Forged 383 Speed Pack, 3.750" Callies Dragonslayer Forged crankshaft, Diamond dome pistons, Diamond Pro-Select rings, Clevite Bearings, Compstar 6.000" connecting rods, 1pc seal $2449.99
Old Jan 2, 2008 | 05:37 PM
  #18
Bowtie4life's Avatar
I am planning on eventually doing this very same thing, but with le2 cam and heads, run on pump gas. Not to jack the thread but was is the advantage of a 6.000" rod length instead of 5.700"?
Old Jan 2, 2008 | 07:00 PM
  #19
rskrause's Avatar
Moderator
The funtional difference between a 6" and a 5.7" rod is minimal. But the piston is lighter with the longer rod. So, unless there is reason to go shrt rod (primarily forced induction( the 6" is a better choice. It won't make any difference in hp though.
Rich
Old Jan 2, 2008 | 07:26 PM
  #20
SS MPSTR's Avatar
Rich
Isn't piston side wall loading less with the longer rod too?
Old Jan 2, 2008 | 08:44 PM
  #21
rskrause's Avatar
Moderator
Yes, the significance gets debated endlessly. It would be hard to measure the difference.
Rich
Old Jan 3, 2008 | 11:37 AM
  #22
thanks guys, again to the op sorry to jack the thread.
pepon214tx
Sep 20, 2015 04:48 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
